![]() | Home > Maintenance & Modifications > Fire extinguisher mount points - share yours thnx! |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3355 ![]() ![]() ![]() |
Giving this old thread a bump as I'd like to mount a fire extinguisher.
More ideas and photos would be appreciated. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4263 ![]() ![]() ![]() |
If you've got some money (unlike me 😁), consider a halon extinguisher. Make much less mess in the event you have to use it. 2007 110 TDCi Station Wagon XS
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2231 ![]() ![]() ![]() |
Pretty sure you will find that Halon has been technically illegal for years except for certain uses (Aircraft, etc.) so you may struggle to even find one.......
The EU ban on the use of Halon in fire extinguishers actually came into force in October 2000 and was implemented in the UK in 2003, as a result of scientific research linking Halon and other CFC’s to Ozone depletion. The ban in practice is not total.
dry powder for class ABC fires |
Only problem is powder can get compacted over time when carried in a vehicle
Ok, no Halon, what am I thinking of then? When I was in a car club around ten years ago everyone was into these extinguishers that didn’t make a mess. Could have sworn it was halon. 2007 110 TDCi Station Wagon XS
Quite possibly but very difficult to get hold of without a legitimate reason or some very 'good' connections.......
I've just noticed that I contributed to this thread nearly three years ago, when I had a different vehicle! On my current 110 USW, I've made use of the dead space in the trim for the non-existent window on the hinge-side of the rear door. I made some brackets from ali channel that bolt to the top and bottom of the side panel, behind the trim:
![]() Click image to enlarge ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
