Home > Puma (Tdci) > Storage Solutions for 110 SW 7seat?
Page 1 of 3 123>
JOW240725
OK I have done a search but I can't find what I'm looking for...
I have a 110 SW and often use all 7 seats so can't loose any. Whilst the cubby and glove box are good for small items and the pedal lock fits nicely under the double middle row seat nicely. What I'm struggling to store securely/safely is the 'recovery gear' i.e. warning triangle, tow rope/shackle/strop, hi viz vest and a few tools? Currently have them stuffed under the single middle row seat but not ideal.
I'm really after a box or something bolted or strapped down, rather than just a loose in the back.
I've considered a MSS slimline box behind the rear most seats but think this will make access for the kids in the back even more difficult.
I wonder if there is anything that could go into the wheel arch or floor? I saw this and wonder where it could fit in a SW? http://www.defender2.net/forum/topic48854.html
The bracket which secures the rear most seat on the wheel arch really gets in the way of a useful space.
Any ideas or solutions would be gratefully received. Anything I should look at at the LRO Show? Thank you Thumbs Up James
Instagram @suffolk_rovers
Post #562415 8th Sep 2016 2:15pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Maybe the Mantec load lugger could be useful as it is easy to remove and put back quite quickly http://www.flatdoguk.com/defender-load-lugger~749
Post #562425 8th Sep 2016 2:41pm
Stacey007
Hello
I'm in the same boat, kids like using the rear seats. I want to make a pull out kitchen for camping and without the chair in its dead easy.
WIth its a pain... they are also not a 5 min job to remove....
Currently I have my bag of bulb, jump leads, warning triangle, tow rope, gloves, socket set etc etc in a black canvas type back that velcros to the floor behind the rear seats, It doesn't move and works quite well.
We use our boot full regularly to carry animal feed and all manor of other stuff so something fixed would be a bit annoying unless some sort of quick release system?
I think a trip to the local DIY store for some MDF, hinges, handles, and some carpet material maybe a solution Smile you could make it so it works around how you use the boot? and even make it so it can come out easy if you need a flat boot.
Post #562427 8th Sep 2016 2:49pm
there was a company who made a MSS type box/drawer that fitted between the 3rd row seats on the boot floor and had clips on the top that the fold out seats clipped into. I can't remember the name of the company now .. but there was also a lot of talk about how safe this idea was due to changing how the 3rd row seats lock into/onto the box top and was it approved.. (or not)
the drawer/box did not go the full length of the boot, so it made a foot well behind the 2nd row for the 3rd row ...
but the idea is a good one ... just needs over engineered solution
Post #562430 8th Sep 2016 3:13pm
josefk
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
"blows own trumpet"
I can get:
shackles x3
bridle x 1
5m strops x2
breaker bar x 1
small but relatively comprehensive socket/torx/hex/ratchet tool kit
warning triangle
hi viz vest x2
gloves
& square of rag
...in the battery box. rattle and stress free.
its a tight fit and I wouldn't want to be using that stuff every day but for a rainy day it works - am I doing something wrong?
also Thumbs Up for the mantec load lugga - one of those things that when you have one you're not sure how you did without...
Post #562431 8th Sep 2016 3:21pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Post #562452 8th Sep 2016 5:10pm
Hairysteve
Post #562455 8th Sep 2016 5:16pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
What you want is the drawer that was sold by Sense of Adventure. I don't know whether they are still in business as the website I had for them no longer works.
It was a short length drawer which started an inch from the back door and finished just before the legroom for the rear seats. It had two brackets on the top that replaced the legs of the seats. However, I am not sure whether it was ever CE marked as it was a critical safety element for the rearmost passengers. Maybe it was, but I remember on here there was a discussion on it.
I have one fitted that I could take a photo of if you wanted. I was going to remove it and sell it as I took the rearmost seats out as I wanted more storage space. Unfortunately, I bolted it in so secure it was going to be an absolute b1tch to take out so didn't bother.
Post #562457 8th Sep 2016 5:19pm
JOW240725
Thanks for suggestions so far. I'll investigate battery box further sounds like you can get quite a bit in!
Not sure the load lugger is going to work for me as i want a permanent storage and kids/friends can want to go in almost on a daily basis.
Bpman and Scotm - that sounds interesting, however the link doesn't work in the posted thread and no sign on 'senseofadventure' on google Big Cry James
Post #562460 8th Sep 2016 5:21pm
JOW240725
smb - it does sound good but it would seem they are no longer available, unless someone else has taken them over?
I need to investigate MSS more as they do a narrow box that fits behind the 3rd row seats without interfering with the seats, just not sure how easy it would be to climb over. I'll look at the LRO Show and hope someone has one on a stand.
Thanks all Thumbs Up James
Post #562461 8th Sep 2016 5:25pm
JOW240725
Hairysteve - that does look ideal! Thank you.
Maybe MSS would replicate something similar? I suspect the CE marking of modifying the seat mounts may cause issues. It would certainly be a concern for me, from an insurance point of view. James
Post #562462 8th Sep 2016 5:29pm
thanks SMB, that was exactly it, I had one but in the end did not fit it. Bought it from CarlW as per the gallery photo.
Post #562463 8th Sep 2016 5:33pm
smb
I must admit I bought mine second hand from someone who bought it new. When they came to fit it they couldn't figure out whether it needed bolting down to the floor or the sides or both. They started to get worried when they tried to find out what testing it has gone through and whether it was completely safe. They gave up in the end as the guy who was SOA was a right arrogant tw.t who kept fobbing them off. I spoke to a number of good suppliers who all told me to be weary of him as he had done the dirty on previous employers in the LR scene.
I tried to buy one direct from SOA and must admit the arrogance was astounding. They wanted all my money, but couldn't tell me when I could have it as they wanted an order for ten before they would make them Shocked
Whether it is legit from a Safety point of view is very questionable and would go on the side of caution and not bother. I don't think I would be able to live with myself if in a serious Head-On I was greated in the front by the rearmost passengers!!
I still have mine fitted, but I have taken out the rearmost seats as with the Top Roof compartment I cannot fit rearmost passengers. I did try, but you would have to be only 2-3 ft tall to be able to fit.
My advice: Forget the idea and go and speak to MSS. I will eventually take mine out and sell it, but not to anyone on here. Too close to home for me.
Post #562658 9th Sep 2016 9:55am
JOW240725
smb - that's very useful information and makes total sense! Thumbs Up
I think I'll make more enquiries to MSS. James
Post #562685 9th Sep 2016 12:24pm
jwb
United States
Another alternative for storage of smaller items are the floor safes (left and right) from GMB.
http://www.gmb-mount.de/shop.htm
Post #562900 10th Sep 2016 12:29pm
Page 1 of 3 123>
