Home > Technical > Let me guess....they all do that - its normal |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
Blithering wipers....bang and now they've stopped mid way.
Grrrr. Any thoughts on where to start looking for ideas on what went wrong? |
24th Aug 2016 8:07pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3648 |
if both have stopped but motor runs then the perhaps the teeth on the gear wheel or the pinion or the cable rack has broken, they are exactly the same arrangement as the old mini ones easy and cheep to fix but hard to get to DEFENDER 90 TDCI XS,
24th Aug 2016 8:12pm |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1977 |
Dashboard out for a £20 fix.....
24th Aug 2016 8:17pm |
Just had a quick look. No noise so motor ain't working. Hopefully just a fuse but I doubt it. Sounded like mechanism seized....was moving slowly prior to bang? Do the mechanisms typically need lubricating - if so from where?
Had park switch replaced before so hoping it ain't that again? |
24th Aug 2016 8:19pm |
Oh great. Got any good news this evening? Waiting for daughter to get home and then I can see it being a long night. |
24th Aug 2016 8:21pm |
If the fuse has popped your wheel boxes have probably seized up. For the sake of £50 I'd replace them with genuine ones. Ray
24th Aug 2016 9:21pm |
Nope. Fuse ain't gone?
But no movement either? |
24th Aug 2016 9:23pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1795 |
I think Black Wolf did an excellent write up on how to lift one end of the dash away to access it all and do the repairs.
At least no one can claim you're imagining this one! Keith |
24th Aug 2016 9:34pm |
yep that's right Keith
Anyhow got the roof lining out but still can't find the motor? Click image to enlarge Last edited by Caterham on 24th Aug 2016 9:50pm. Edited 1 time in total |
24th Aug 2016 9:48pm |
Both wipers seem to be very stiff with surprisingly little play?
Got the dynamat n first section of roof lining fitted though |
24th Aug 2016 11:19pm |
thanks BW. motor has thermal protection?
does that mean it has it's own fuse? what needs to be done to reset / fix once the thermal protection has cut in? many thanks, |
25th Aug 2016 8:34am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17491 |
No, I can't remember the details but it stops before it spontaneosly combusts if the wipers are stuck to the screen, or, as happens more commonly on a Defender, the wheelboxes have jammed. If it didn't, even if you turn the wipers off, the motor will still be trying to park them if the ignition is on.
No reset is necessary, all you need to do is unjam or unstick the wipers. There is a fuse as well, of course, to pretect against electical malfunction. |
25th Aug 2016 11:50am |
thanks BW
I wonder if it's a new motor then - or repairable? seems like something re; wheel boxes / rack needs replacing too bvgger. ! |
25th Aug 2016 11:53am |
£150 ish for genuine motor and wheel boxes isn't too bad really when you think of how much you've blown on imaginary problems. At least this is real. Ray
25th Aug 2016 12:19pm |
