Home > Technical > Let me guess....they all do that - its normal
Caterham
Blithering wipers....bang and now they've stopped mid way.
Grrrr.
Any thoughts on where to start looking for ideas on what went wrong?
Post #558696 24th Aug 2016 8:07pm
LR90XS2011
if both have stopped but motor runs then the perhaps the teeth on the gear wheel or the pinion or the cable rack has broken, they are exactly the same arrangement as the old mini ones easy and cheep to fix but hard to get to DEFENDER 90 TDCI XS,
Post #558700 24th Aug 2016 8:12pm
Huttopia
Dashboard out for a £20 fix.....
Post #558702 24th Aug 2016 8:17pm
Caterham
Just had a quick look. No noise so motor ain't working. Hopefully just a fuse but I doubt it. Sounded like mechanism seized....was moving slowly prior to bang? Do the mechanisms typically need lubricating - if so from where?
Had park switch replaced before so hoping it ain't that again?
Post #558704 24th Aug 2016 8:19pm
Caterham
Oh great. Got any good news this evening?
Waiting for daughter to get home and then I can see it being a long night.
Post #558705 24th Aug 2016 8:21pm
mk1collector
If the fuse has popped your wheel boxes have probably seized up. For the sake of £50 I'd replace them with genuine ones. Ray
My build thread
Post #558727 24th Aug 2016 9:21pm
Caterham
Nope. Fuse ain't gone?
But no movement either?
Post #558729 24th Aug 2016 9:23pm
ickle
I think Black Wolf did an excellent write up on how to lift one end of the dash away to access it all and do the repairs.
At least no one can claim you're imagining this one!
Keith
Post #558733 24th Aug 2016 9:34pm
Caterham
yep that's right Keith
Anyhow got the roof lining out but still can't find the motor?
Post #558736 24th Aug 2016 9:48pm
Rattle each wiper, probably one will be have a bit of movement and one will be stuck. Gentle waggle the stuck one, it will probably then free off and the wipers will park.
If the above comes to pass it is due to wear in the wheelboxes, and the solution is to replace them (which requires the dash to be freed off and pulled back from the bulkhead but not removed). A short term fix can be achieved by removing the motor and drive rack inner cable thingy, rotating the spindles 180 degress, and reassembling.
The Puma wiper motor has thermal protection so it usually doesn't blow the fuse if it stalls (and it is of course located in front of the passenger obetween the plastic dash and bulkhead, not in the roof, as I am sure you know).
Post #558737 24th Aug 2016 9:48pm
Caterham
Both wipers seem to be very stiff with surprisingly little play?
Got the dynamat n first section of roof lining fitted though Thumbs Up
Post #558748 24th Aug 2016 11:19pm
Caterham
thanks BW. motor has thermal protection?
does that mean it has it's own fuse? what needs to be done to reset / fix once the thermal protection has cut in?
many thanks,
Post #558797 25th Aug 2016 8:34am
No, I can't remember the details but it stops before it spontaneosly combusts if the wipers are stuck to the screen, or, as happens more commonly on a Defender, the wheelboxes have jammed. If it didn't, even if you turn the wipers off, the motor will still be trying to park them if the ignition is on.
No reset is necessary, all you need to do is unjam or unstick the wipers.
There is a fuse as well, of course, to pretect against electical malfunction.
Post #558841 25th Aug 2016 11:50am
Caterham
Thumbs Up thanks BW
I wonder if it's a new motor then - or repairable?
seems like something re; wheel boxes / rack needs replacing too Crying or Very sad
bvgger. !
Post #558845 25th Aug 2016 11:53am
mk1collector
£150 ish for genuine motor and wheel boxes isn't too bad really when you think of how much you've blown on imaginary problems. At least this is real. Whistle Ray
My build thread
Post #558854 25th Aug 2016 12:19pm
