Home > Technical > Who wants a Nanocom Evolution
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 6 of 9 <123456789>
nakatanenga
Germany
It will take 2-4 days after recieving payment.
BUT: I need to ship it to the confirmed paypal adress, otherways PP is going to kick my a....
Peter WANTED:
SII or SIII in max 1.5k
Post #51048 4th Jan 2011 8:23pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Email sent Thumbs Up 130 crew cab
98 V8 Disco
Post #51075 4th Jan 2011 9:34pm
mse
We should all be good (thanks) Thumbs Up Thumbs Up Mike
Post #51093 4th Jan 2011 9:57pm
aaronmorris
sent you an email peter Thumbs Up
Post #51094 4th Jan 2011 10:02pm
walpoleer
United Kingdom 2000 Defender 90 Td5 SW Auto Epsom Green
cheers Peter, great service thanks just starting out and getting it all wrong..so I'am told, and have a disco 2 but thats not an option as it was the wife choice. and she has never known herself to be wrong.
Post #51141 5th Jan 2011 10:02am
BigRuss
Just a quick question,
Is the nanocom unit to be uses as well as or instead of the scanurgauge??
I see that they do similar things but the nanocom is much bigger.
Also it the nanocom is to replace the scanurgauge where do you plan on mounting it? Russell
2011MY 110 XS USW Black
Post #51159 5th Jan 2011 2:32pm
Lorryman100
Russell, the scangauge is fitted in my landy permanently to monitor water temp, air temp etc and reset any fault codes to get me home if the need arises. Due to its size it is ideal compared to mounting the nanocom which as you say is much bigger. The scangauge is just a very handy and cheap scan tool, as you cannot change anything in the ecu with it. The nanocom is a very different beast as it allows programming of key fobs, injectors etc. Also goes into more detail in monitoring vehicle systems than the scangauge to allow fault finding. I personally would not leave this in the vehicle mounted as you can bypass the alarm and immobiliser with it meaning a scrot in the know could hotwire your landy and be away with it. (Admittedly the alarm would sound until bypassed) Will look into this more once I get the OBDII splitter cable as it is a right royal pain just now disconnecting the scangauge to allow the nanocom to be fitted Big Cry I would like to have the time to plug in the nanocom and go through everything it does to allow me a better understanding of the systems menus and options. HTH
Post #51201 5th Jan 2011 7:19pm
mse
Thanks to both Peter and Brian for sorting this unit Mike
Post #52367 11th Jan 2011 1:12pm
CFB
Mine just arrived but I can't register or unlock it as the webpage isn't working Big Cry Big Cry Big Cry Andy
Post #52378 11th Jan 2011 1:30pm
mse
Just refresh and try again...mine did that Mike
Post #52380 11th Jan 2011 1:39pm
CFB
Nope, refreshed it a dozen times but no go, have emailed Peter Andy
Post #52382 11th Jan 2011 1:50pm
CFB
Got it to register by just putting the product code and email address in, if I tried to add my name/address etc it didn't work Andy
Post #52387 11th Jan 2011 2:14pm
walpoleer
Mine arrived today, found the same, the registration only worked with the minimum required fields filled in E-Mail and product code, the password arrived in my inbox within a couple of minutes, thanks again to Peter and Brian for getting this set up. just starting out and getting it all wrong..so I'am told, and have a disco 2 but thats not an option as it was the wife choice. and she has never known herself to be wrong.
Post #52439 11th Jan 2011 8:52pm
mse
Seems we all have Nancoms now Whistle Im sorry if i started something Big Cry blame my wife for not just getting it me Thumbs Up Mike
Post #52469 11th Jan 2011 10:13pm
CFB
I'm having major problems with mine, its Censored up the SLS Air Suspension on my DiscoII which is now sinking to the bump stops every time the ignition goes off. Problem seems to be with writing any setting changes.
Have emailed Peter again for help Big Cry
PS. Has anyone tried to upgrade the firmware as I have been unable to do so Andy
Post #52544 12th Jan 2011 12:44pm
This topic is locked: you cannot edit posts or make replies.  Back to top
