- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > Britpart HD clutch kit.... anyone? |
TC
Re: Britpart HD clutch kit.... anyone? | |
diesel_jim wrote:Has anyone here used the Td5 Britpart HD kit?
From what i gather, it just uses a DII V8 friction plate (and cover plate i assume), not sure about the thrust bearing.
And a solid flywheel. this is the crux.... how well machined it is? i've heard one or 2 other people say the kit is OK. Just wondered if anyone here has experience of it?
Rakeway do a kit, and via a forum member i can get it for about £300 + vat, but i reckon the Britpart might be a bit cheaper. not sure. may be possible to buy just the solid flywheel then buy V8 clutch from my local autofactors??
I am in no way an expert but not sure how I would feel relying on Britpart for a clutch......
20th Dec 2010 9:47am |
