Home > Td5 > TD5 Defender Lack of Power
Page 1 of 3 123>
Lund
United Kingdom 2003 Defender 90 Td5 PU Caledonian Blue
Hi all,
I'm new here and just purchased a TD5 Defender. I know about TD5 issues; namely the EGR, MAF & Oiled loom and appear to have bought a defender with all of them!
Sometimes the Defender is boosting, sometimes not. I have managed to free the actuator a little, but it's stiff and I can't really move it by hand all that easily. I have drowned it in rock oil and it is better than what it was. When I say, not boosting; it feels as though the turbo is making a lot of noise, but not going anywhere!
I have ordered a new loom and cleaned all of the oil creep from the ECU. I'll fit the loom tomorrow all being well and see if that makes a difference?
I also unplugged the MAF, but didn't notice any difference what so ever. Could it be the MAF?
Is there anything else I should be checking/addressing?
Cheers,
Lund
Post #546693 6th Jul 2016 9:14pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Waiit till youve done the loom as it can be night and day afterwards.
Count the threads on the waste gate, it shiuld be about 11 if memory serves, mine came loose and it was as slow as s**t, also check brakes are not dragging, fuel pump etc is good 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #546733 7th Jul 2016 1:21am
Nick666
United Kingdom 1986 Defender 90 2.5 n/a Diesel SW Yellow
Also (as I've found) check that the exhaust manifold isn't warped and leaking out past the gasket - I've done all the aforementioned and turns out it was that although given there was grease and whatnot everywhere it wasn't as obvious as I'd have expected. Made a HUGE difference fixing that. Easy to find if you spray a bit of WD40 on it at idle (cold) as will bubble out round the leaking area of the gasket. (Apols if teaching you to suck eggs, I'm a noob myself so could be dead obvious to everyone else!)
Post #546797 7th Jul 2016 10:25am
Nick666
Re: TD5 Defender Lack of Power
I tried this - understand if it's the MAF it should result in a pretty obvious improvement if you unplug it (although not as good as if working properly)... it wasn't the MAF on mine although replaced it anyway. If you do, everywhere I've read says buy genuine btw!
Post #546799 7th Jul 2016 10:28am
Gav40
United Kingdom 1998 Defender 90 Td5 HT Chawton White
Hi, in my experience the turbo actuator rod is meant to be stiff to move and you are unlikely to be able to move it by hand, usually a wiggle with a pair of grips is enough to free it off.
Have you got access to a code reader? This would tell you is the Maf sensor was not working or had a low reading. Mine was reading a little low at idle and was changed for a new one and has made a difference in low down torque more than anything else. The values changed from about 35 to 60 at idle warm engine.
Only get a original or OE one though as said before
Post #546867 7th Jul 2016 3:03pm
Lund
Hi all,
Thanks for your replies. I have had the actuator off and used rock-oil/plus gas to work it. It's stiff, but I can get full movement with pliers.
I have replaced the MAF for a new unit and I have also changed the rocker cover loom. All oil has been cleaned from the red plug, and I'll continue to pull & clean it over the next few weeks to clear the remaining oil.
The MAF is still no different whether it is plugged or unplugged. I have also pulled the intercooler hoses and they're all clear, with just a light misting of oil. All hoses appear to be in good working order.
I can't see any obvious signs of a gasket leak. I also replaced is the fuel filter on the chassis and did the purge trick.
Tried plugging in with SNAP-ON, BOSCH & Autel diagnostics but non would communicate with the Land Rover, but did get power from the OBD. Is it a case of having to use Land Rover specific diagnostics?
I'm at a loss!
Post #547629 10th Jul 2016 7:42pm
mk1collector
Try find someone with a nanocom near where you live. Ray
My build thread
Post #547670 10th Jul 2016 9:16pm
Lund
Located in Wirral Very Happy
Post #547811 11th Jul 2016 2:32pm
excossack
There is a growing number on the Wirral!
You could try Mike at http://www.dynachip.co.uk/ - Neston way (near what used to be Gingers scrap yard, on the road from Thornton Hough to the chester high road) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #547815 11th Jul 2016 2:49pm
Lund
Cheers. Just checked the MAP & pulled the hose off the EGR; both as clean as a whistle, it's like it has done a lot less miles than it has!
Noticed an exposed wire on the red plug to the ECU, a potential issue?
ETA: Just taken it for a good run and it's better for it. Seems alot more lively when it's made temp. Only really sluggish when cold. Still cant notice any difference between MAF on or off.
Post #547889 11th Jul 2016 7:00pm
yanto
Wales
My 2003 90 is slow until up to temp.
Post #548298 12th Jul 2016 8:58pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Injector seals? I have just done the loom and these on mine and cured the problem. Mine was also fine with or without MAF. 2002 110 td5
Post #548313 12th Jul 2016 9:15pm
Anderzander
I'm just the other side of Preston and have a Nanocom, if you were up this way let me know and we could plug it in for you.
Post #548355 13th Jul 2016 2:50am
Lund
It does seem a different beast when it's up to temp, thing is I only do short miles.
I'll check it out Thumbs Up
Thank you kindly for the offer, I have phoned Mike @ Dynachip as he is only round the corner from me, but I suspect he is on holiday at the moment.
Last night I changed the engine oil & all filters, flushed and bled the clutch, fixed the pedal squeak with white grease, replaced the front & rear axle oil with EP90... getting there!
Post #548404 13th Jul 2016 8:54am
miker
My TD5 is the same!
Post #548410 13th Jul 2016 9:25am
Page 1 of 3 123>
