Home > Puma (Tdci) > Wheel bearing grease
RlpV8
England 2012 Defender 90 Puma 2.2 XS CSW Indus Silver
Can somebody tell me what grease I need to use for the front wheel bearings I am about to change on my 2012 2.2 Puma TDCi please?
Post #541125 17th Jun 2016 8:11pm
I still use Castrol LM, but it's very difficult to find now. Big Cry
Fortunately I have a reasonable stock.
Post #541161 17th Jun 2016 10:08pm
miker
Euro Car parts do a lithium ep grease for not much money, designed for wheel bearings. Holding up fine in mine at least!
http://www.eurocarparts.com/ecp/p/car-acce...mp;cc5_150
Post #541172 18th Jun 2016 12:59am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
If it rotates, lithium based; if it slides (king pins etc.), molybdenum based - that 'orrible black stuff that gets everywhere. But I've yet to hear of anyone greasing a prop-shaft sliding joint with moly.
Until today, that is!
Peter
Post #541205 18th Jun 2016 9:02am
Merlin
Post #541236 18th Jun 2016 11:34am
RlpV8
Wheel bearings
Thanks for that, found some Castrol LM so that's sorted. Now the problem is do I have the right bearing? I called LR Centre and asked what I need as their website wasn't clear (to me anyway), they assured me I needed DA2381G which I ordered but it says on the box wheel bearing kit def 94 on and inside it has a pair of bearings, oil seal 5 bolts, cap, 2 nuts tab washer, circlip and a gasket. Now I'm sure I read somewhere that the newer hubs only had one nut so is the wrong kit? You might think I should just strip it down and find out myself but I can only have the Landie of the road for the day as it is constant use so I want to make sure I have everything I need before I tackle it. Thanks.
Post #542823 23rd Jun 2016 7:53pm
Dave-H
Yep, you have the earlier Defender kit. TD5 onwards models have a spacer between the bearings for correct float, and a single locknut that torques on.
The kit you have will do the job, some people revert back to the two nut system so they can re-adjust bearing float as required... personally I think the later one nut system is not only correct but more precise reliable. Guns and Landrovers .... anything else is irrelevant.
Post #542827 23rd Jun 2016 8:14pm
RlpV8
Wheel bearings
Thanks Dave, I thought that was the case. I'll give them a call tomorrow and get it changed.
Post #542833 23rd Jun 2016 8:27pm
agentmulder
Kuwait
You may want to to keep hold of that kit, have a read here:
http://www.defender2.net/forum/topic47197.html
Thumbs Up Solved the bowel problem, working on the consonants...
Post #542847 23rd Jun 2016 9:11pm
RlpV8
Wheel bearing
Just started to do this wheel bearing and been baulked by the caliper bolts. What was wrong with hex bolts? Can anyone tell me what size those torx bolts are just been to Halfords bought a set and none were big enough.
Post #547177 8th Jul 2016 7:20pm
Rickydodah
If it's these bolts that you mean ISTR that they're are 13mm double hex. You need a 12point socket or ring spanner. They can be bas**rd tight too. Thumbs Up I started with nothing and still have most of it left!
Post #547194 8th Jul 2016 8:02pm
RlpV8
Yep they're the ones just checked my sockets again all 6 point. Off to Halfords in the morning then. Thanks for the speedy reply.
Post #547200 8th Jul 2016 8:13pm
miker
Yep, double Hex! I did the same, mid-afternoon run to halfords for a set of 1/2" sockets!
And done up FT too!
Post #547243 8th Jul 2016 11:15pm
agentmulder
Kuwait
Re: Wheel bearing
Can be rounded off when torquing up to the spec required in this application. 12 point much less so... Solved the bowel problem, working on the consonants...
Post #547249 9th Jul 2016 12:48am
RlpV8
Just fitted the bearings old tyle, should I have letf the spacer out of the middle between the bearings as I can't get the splined cover on now using the two nuts? *** Panic over I worked it out. This kit must be a mixture of the two, should have looked at the nuts more closely. Just put the spacer back in the middle left out thatt thin nut that came with the kit and all fits correctly.
Post #547312 9th Jul 2016 12:04pm
