![]() | Home > Puma (Tdci) > Wheel bearing grease |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
I still use Castrol LM, but it's very difficult to find now.
![]() Fortunately I have a reasonable stock. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
Euro Car parts do a lithium ep grease for not much money, designed for wheel bearings. Holding up fine in mine at least!
http://www.eurocarparts.com/ecp/p/car-acce...mp;cc5_150 |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 883 ![]() ![]() ![]() |
If it rotates, lithium based; if it slides (king pins etc.), molybdenum based - that 'orrible black stuff that gets everywhere. But I've yet to hear of anyone greasing a prop-shaft sliding joint with moly.
Until today, that is! Peter |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
CV2:
http://www.redlineoil.com/product.aspx?pid=82 Merlin |
RlpV8 Member Since: 31 May 2014 Location: Northampton Posts: 25 ![]() ![]() ![]() |
Thanks for that, found some Castrol LM so that's sorted. Now the problem is do I have the right bearing? I called LR Centre and asked what I need as their website wasn't clear (to me anyway), they assured me I needed DA2381G which I ordered but it says on the box wheel bearing kit def 94 on and inside it has a pair of bearings, oil seal 5 bolts, cap, 2 nuts tab washer, circlip and a gasket. Now I'm sure I read somewhere that the newer hubs only had one nut so is the wrong kit? You might think I should just strip it down and find out myself but I can only have the Landie of the road for the day as it is constant use so I want to make sure I have everything I need before I tackle it. Thanks.
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Yep, you have the earlier Defender kit. TD5 onwards models have a spacer between the bearings for correct float, and a single locknut that torques on.
The kit you have will do the job, some people revert back to the two nut system so they can re-adjust bearing float as required... personally I think the later one nut system is not only correct but more precise reliable. Guns and Landrovers .... anything else is irrelevant. |
Thanks Dave, I thought that was the case. I'll give them a call tomorrow and get it changed.
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
You may want to to keep hold of that kit, have a read here:
http://www.defender2.net/forum/topic47197.html ![]() |
Just started to do this wheel bearing and been baulked by the caliper bolts. What was wrong with hex bolts? Can anyone tell me what size those torx bolts are just been to Halfords bought a set and none were big enough.
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
![]() If it's these bolts that you mean ISTR that they're are 13mm double hex. You need a 12point socket or ring spanner. They can be bas**rd tight too. ![]() |
Yep they're the ones just checked my sockets again all 6 point. Off to Halfords in the morning then. Thanks for the speedy reply.
Yep, double Hex! I did the same, mid-afternoon run to halfords for a set of 1/2" sockets!
And done up FT too! |
Can be rounded off when torquing up to the spec required in this application. 12 point much less so... Solved the bowel problem, working on the consonants... |
Just fitted the bearings old tyle, should I have letf the spacer out of the middle between the bearings as I can't get the splined cover on now using the two nuts? *** Panic over I worked it out. This kit must be a mixture of the two, should have looked at the nuts more closely. Just put the spacer back in the middle left out thatt thin nut that came with the kit and all fits correctly.
