Home > Puma (Tdci) > Engine block preheater
Page 3 of 3 <123
BigMike
cheers - are we talking epersbacher though or webasto?
Post #48286 12th Dec 2010 6:17pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Both use the same type of pump Thumbs Up
Post #48288 12th Dec 2010 6:34pm
BigMike
that's interesting, cheers Sonic. Can you make me a sonic special fuel box Laughing
Post #48289 12th Dec 2010 6:39pm
Sonic3d
Far too busy with work and bolting bits to the Disco Whistle Give Allisport a ring about making a wing top tank Thumbs Up
Post #48292 12th Dec 2010 6:51pm
BigMike
Ah I just read the other thread where you mention the metallics guy making yours. I'll have a word with Allisport, cheers.
How'd you do the ducting from the heater to the roof tent? did the duct not lose a lot of heat due to the distance? and what material of hose did you use? I guess with your heater being outside of the truck you didnt have any issues with exiting the vehicle with the duct anyway..
Post #48293 12th Dec 2010 7:03pm
mse
If i was putting a tank on the 90 i wouldnt put it in the engine bay - i would put it under the drive passenger rear wing right behind the door.
With some simple tap filler arrangement. Mike
Post #48400 13th Dec 2010 7:15pm
Sonic3d
I used a flexible 60mm silicone hose that has a steel spiral in it to prevent it collapsing, heat loss was not a problem Thumbs Up managed to have over 20degrees in the tent when only 1 or 2 outside Very Happy
Post #48405 13th Dec 2010 7:24pm
Sonic3d
Filling rear wing tanks is awkward, the problem is where to fit a filler without drilling the body.
Post #48406 13th Dec 2010 7:26pm
BigMike
Excellent.
I looked under the front wing top earlier. I cant be arsed to move stuff, take it out and replace, though admittedly it would be great to put a spring catch on the blanking plate on the wingtop and have the tank underneath and fill it that way.
I have an aux tank under the o/s rear wing anyway, so the other place is n/s rear. I'm going for an eberspacher not a webasto, and i m going to fit it on the wheel box top n/s so a tank under there would make the most sense. its just filling it that will be a Censored so i m going to get someone to make one for me, probably in steel rather than alloy for the bracket strenth. May well have to fill using a pipe and funnel which isnt ideal. I guess I'll need a fill level indicator on the side of the tank
Post #48418 13th Dec 2010 7:49pm
BigMike
definitely not enough space under the wing top. So I'm looking at having a 1.5 gallon tank fabricated to go under the sill, but having the filler pipe go up into the wing top so the filler would be accessed via the blanking plate on the n/s wing. Going to put a spring loaded hinge on the back of it and a locking catch and that should be a pretty cool solution.
Post #48473 14th Dec 2010 12:24pm
Lorryman100
Thought that the near side vent was for the heater air intake?
Post #48483 14th Dec 2010 1:02pm
BigMike
durr yes of course, it'd be offside. my mistake in my excitement at being able to lift the wing flap and fill a tank Laughing
Post #48487 14th Dec 2010 1:11pm
Page 3 of 3 <123
