![]() | Home > Puma (Tdci) > Engine block preheater |
cheers - are we talking epersbacher though or webasto?
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Both use the same type of pump ![]() |
that's interesting, cheers Sonic. Can you make me a sonic special fuel box
Far too busy with work and bolting bits to the Disco
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
If i was putting a tank on the 90 i wouldnt put it in the engine bay - i would put it under the drive passenger rear wing right behind the door.
With some simple tap filler arrangement. Mike |
I used a flexible 60mm silicone hose that has a steel spiral in it to prevent it collapsing, heat loss was not a problem ![]() ![]() |
Filling rear wing tanks is awkward, the problem is where to fit a filler without drilling the body. |
Excellent.
I looked under the front wing top earlier. I cant be arsed to move stuff, take it out and replace, though admittedly it would be great to put a spring catch on the blanking plate on the wingtop and have the tank underneath and fill it that way. I have an aux tank under the o/s rear wing anyway, so the other place is n/s rear. I'm going for an eberspacher not a webasto, and i m going to fit it on the wheel box top n/s so a tank under there would make the most sense. its just filling it that will be a ![]() |
definitely not enough space under the wing top. So I'm looking at having a 1.5 gallon tank fabricated to go under the sill, but having the filler pipe go up into the wing top so the filler would be accessed via the blanking plate on the n/s wing. Going to put a spring loaded hinge on the back of it and a locking catch and that should be a pretty cool solution.
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Thought that the near side vent was for the heater air intake?
durr yes of course, it'd be offside. my mistake in my excitement at being able to lift the wing flap and fill a tank
