![]() | Home > Td5 > TD5 seems a bit underpowered |
Nick666 Member Since: 23 Mar 2016 Location: Somerset / Dorset borders! Posts: 81 ![]() ![]() ![]() |
Hmm, gazman mentioned the FPR too. Well, I'll replace the gasket and exhaust manifold since I've ordered those already, and see what she runs like - sounds like the FPR's the next obvious bet!
[Now to look up how I test fuel pressure without just buying a new pump and regulator or insanely expensive testing kit!] |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
I have just replaced the injector harness and it has cured my lack of low down power. I have a steep drive and my defender can usually crawl its way up quite easily on tick over. Over the last few months it had been unable to do this without stalling and there was what felt like massive turbo lag. There was no spluttering at all. The harness was two and a half years old (I have no life, I keep a spreadsheet ![]() Also, maybe your turbo to intercooler hoses are in poor condition? 2002 110 td5 |
Good tip about the harness - I'll leave that til I've tried a couple other things, but worth having in the back of my mind in case it's that and just hasn't travelled all the way down to the ECU yet!
Intercooler hoses are high up my list of to-do's, definitely ![]() |
If that was your problem I might change mine just to see if there's a difference even though my maf was definately finished. Ray My build thread http://www.defender2.net/forum/topic17615.html |
It surprised me actuall, because like the OP, I thought symptoms were misfires caused by oil in the ecu. As you know mine had no oil there so can only assume the oil had got past the silicone I had put in and caused some sort of electrical error within the harness...weird.
I got the Land Rover centre to put mine on their diagnostics where they could read live data. The MAF was working fine as we suspected. It was really interesting. Mark showed me everything it could read and explained how they use the information to diagnose problems (obviously), but it is interesting to see it with your own eyes on your vehicle. 2002 110 td5 |
Is yours totally fine now then? Ray
It certainly seems that way. The final proof will be the next time I fill up when I can check the mpg 2002 110 td5
Must admit I'm tempted (although it's big bucks) to get a Nanocom. Will have to look up whether there's anything it doesn't cover (given that sod's law dictates that would be what's wrong with it!)
Anyway, I found some silicone hoses for a good price so I've ordered those - they'll need doing at some point even if they're not causing trouble yet. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
There were rumblings of a nanocom group buy, I'm tempted by one still.
Check the turbo for excessive wear ( too much play in the turbine bearings ) and also look for any oil etc in the induction system, if the intercooler is full of gunk this will effect it. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
We put jimb1978's 110 on my nanocom and it didn't bring up his fault which I believe turned out to be the injector loom. Ray My build thread http://www.defender2.net/forum/topic17615.html |
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 ![]() ![]() |
Just for the record, i have just replaced my actuator on my 2001 td5 with 64000 miles on it, and it seems to have made a nice difference, can feel the boost coming in better...
I had to loosen it up quite a bit to get it moving smoothly again, loads of WD40 and moving it about using a 15mm (if I recall corrrectly) spanner which fits perfectly over the top. Which is easy once you can get to it, the heatshield was in such a mess that had to be binned (again, thanks, previous owners!)
Glad you mentioned this now, hoses arrive tomorrow so I'll have a look through it all for gunk while I'm at it! ![]() ![]() |
