Home > Technical > Removing siezed vent flap bolts
landybear
United Kingdom 2003 Defender 90 Td5 HT Belize Green
Does anyone have any tips on how to remove the vent flap hinge bolts if they are rusted into the bulkhead hinge? I have some stainless replacements that need fitting and have been soaking in WD40 for some time but currently they are refusing to budge. I'm wary of hammering too much in case it damages the mounting so hopefully I'm missing a trick?? 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous)
Disco 2 Landmark 2004, 2001, 2002 (Previous)
Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous)
Defender 110 300tdi 1993 (Previous)
Range Rover Vogue 4.6 - 2001 (Previous)
Freelanders TD4 (2001 3 door & 2002 5 door) Previous
90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others
Post #537528 4th Jun 2016 6:40pm
gilarion
I have never found WD 40 any good for un-seizing very rusty fixings, it tries too hard to be all things and ends up doing none of them very well.
I always use Plusgas much more searching. Or Halfords Shock & Unlock Spray, which combines powerful penetrating fluids and freezing agents which "shock free" rusted fixing. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #537532 4th Jun 2016 6:55pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Mine were also seized. Just a case of working the pin round each way. Once it starts moving, it moves more and more and will come out Thumbs Up
Post #537565 4th Jun 2016 9:10pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Mine are stuck fast, to the point I cut though the pins so I could remove the vent and carry on with the bulkhead repair. So I now have half a pin stuck in the bulkhead part of the hinge. I too am wary about hitting it out. I'm currently soaking them in Plusgas.
I did wonder about making a tool to hold the hinge and push the pin out. I'll see how the Plusgas route goes!
Any other ideas welcome. Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #573704 27th Oct 2016 1:58am
PlusGas and/or the application of heat.
Post #573714 27th Oct 2016 8:00am
Wurth Rost off Ice works a treat Thumbs Up
Post #573718 27th Oct 2016 8:40am
TechnoTurkey
2005 Defender 110 Td5 CSW Zambezi Silver
I managed to get one pair out of mine but the drivers side are still stuck fast, I've hammerd them so much that I've mushroomed the end of the thread now!
Post #573720 27th Oct 2016 9:04am
Living up to your Forum name then Rolling with laughter
Post #573721 27th Oct 2016 9:40am
mk1collector
I found taking the two bolts out that hold it to the opening knob gives you lots more movement of the vent flap itself so breaks the rust hold better and coupled with copious amounts of any of the products mentioned above they should start to move. The two bolts are undone from under the vent flap when it's open Thumbs Up Ray
My build thread
Post #573775 27th Oct 2016 1:29pm
MC84
Thanks Guys. I've got the vent off, which was moving freely, by cutting thought the pins. The parts of the pins left in the hinge attached to the bulkhead are the bits I'm trying to get out. I don't want to bash them or apply heat really as I have enough repair work to do already. I'll come up with something that will (I hope) press the pins out. Fingers crossed! I do have the pins soaking with Plusgas which I have found works wonders.. Mike
Ford 100e 1959
Post #573899 28th Oct 2016 2:11am
MC84
In the end I made a little clamp up to get the pins out. A bit crude but it worked a treat!!
[/img][URL=]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Mike
Ford 100e 1959
Post #574815 1st Nov 2016 8:27pm
TechnoTurkey
You could hire that out!
Post #574920 2nd Nov 2016 10:02am
MC84
Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #575002 2nd Nov 2016 7:51pm
