![]() | Home > Technical > Removing siezed vent flap bolts |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
I have never found WD 40 any good for un-seizing very rusty fixings, it tries too hard to be all things and ends up doing none of them very well.
I always use Plusgas much more searching. Or Halfords Shock & Unlock Spray, which combines powerful penetrating fluids and freezing agents which "shock free" rusted fixing. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
Mine were also seized. Just a case of working the pin round each way. Once it starts moving, it moves more and more and will come out
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
Mine are stuck fast, to the point I cut though the pins so I could remove the vent and carry on with the bulkhead repair. So I now have half a pin stuck in the bulkhead part of the hinge. I too am wary about hitting it out. I'm currently soaking them in Plusgas.
I did wonder about making a tool to hold the hinge and push the pin out. I'll see how the Plusgas route goes! Any other ideas welcome. Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
PlusGas and/or the application of heat.
Wurth Rost off Ice works a treat
TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88 ![]() ![]() |
I managed to get one pair out of mine but the drivers side are still stuck fast, I've hammerd them so much that I've mushroomed the end of the thread now!
Living up to your Forum name then
I found taking the two bolts out that hold it to the opening knob gives you lots more movement of the vent flap itself so breaks the rust hold better and coupled with copious amounts of any of the products mentioned above they should start to move. The two bolts are undone from under the vent flap when it's open
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Thanks Guys. I've got the vent off, which was moving freely, by cutting thought the pins. The parts of the pins left in the hinge attached to the bulkhead are the bits I'm trying to get out. I don't want to bash them or apply heat really as I have enough repair work to do already. I'll come up with something that will (I hope) press the pins out. Fingers crossed! I do have the pins soaking with Plusgas which I have found works wonders.. Mike
In the end I made a little clamp up to get the pins out. A bit crude but it worked a treat!!
![]() Click image to enlarge[/URL] [/img][URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
You could hire that out!
![]() ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
