Home > Puma (Tdci) > How to stop the wipers when squirting the windscreen??
Page 2 of 2 <12
macfrank
Hi, I just tried to do this but can‘t get past step 3 unclip relay base :-/
I tried to lift the tab the screwdriver point to in picture 2. I also tried to push it down, but it wont move in that direction.
I didn‘t want to apply too much force and have no mental picture of how the base is held in place.
Post #999183 8th Jul 2023 12:07pm
It's much easier to bend the spade pin of the relay at 90° (or even cut it off) so it doesn't enter the relay socket than it is to mess about with the socket.
Post #999191 8th Jul 2023 1:20pm
macfrank
You're probably right blackwolf. I have a .99 relay somewhere anyway, so I think I'll give it a try cutting off the pin.
Post #999194 8th Jul 2023 1:58pm
I just folded the pin flat against the base of the relay, easier than cutting. It is literally a sub-sixty-second modification and a huge improvement.
Post #999202 8th Jul 2023 2:32pm
macfrank
Thanks for pointing out the simplest solution Smile I finally got round to install the 99 relay and it's great, even without modifications. short press - single wipe Thumbs Up
Post #1002294 30th Jul 2023 5:11pm
keith
Which pin did you remove BW From this wiper relay?
Post #1058214 22nd Jan 2025 12:13pm
It's the one that industry calls "T", Land-Rover calls C0303R-6, and is the one in the top right of your photo.
If you just bend it flat it will have the same effect, can't touch anything, but (probably) allows you to change your mine at least once.
Post #1058246 22nd Jan 2025 4:02pm
keith
Thumbs Up
Post #1058320 23rd Jan 2025 11:55am
Page 2 of 2 <12
