![]() | Home > My Defender > My first Landrover and plans for it |
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 ![]() |
Hiya,
Well the full width load mat is a genuine LR one, fitted one when we got our HT about 130 quid from the dealer. Wheels Genuine LR HD steels somewhere around 60 quid each plus tyres, theres a recent thread one here regarding steel wheels if I can find it. 3 Landrovers |
This thread? http://www.defender2.net/forum/topic31672.html
The wheels in the first Defender you said you liked were the standard duty steel wheels with Michelin Latitude 7.50 tyres. The wheels in the second one are the HD Wolf wheels with 235 Goodyear MTRs. |
Dtfrith Member Since: 01 Nov 2014 Location: Manchester Posts: 76 ![]() ![]() |
Great! Thank you guys. I will let you know how I get on with the appraisal.
The existing grille and headlight surrounds you have are KBX and you can sell those easily and for good money.
The look you are going for is standard Land Rover grille and headlight surrounds, cheap as chips and possibly even free if you put up a wanted advert |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
My 110 came with the KBX set and I too swapped it for the factory spec.
The net total to and fro meant that $$ came my way ![]() Funny, I want wolf wheels on mine too, but the cost in shipping is painful down this way. I did get one, which is now my spare, the studs will allow enough thread to get you moving, but I'm not convinced it's the best thing for a permanent set up, so the studs (x20) add to the cost (for me at least). Not sure if you wanted to, but I wouldn't remove the tread plate (your goal image doesn't have any), you'll be left with holes to plug... Also, small chance you're not aware, but your intended look may be part informed by the puma 'bump' in the hood, IMO it's a total affectation. The vehicle in the pic doesn't have aircon, which as far as I'm aware means it's not a puma spec itself (?), I'd stay with yours personally, quite fetching, but more to the point: model accurate (once you remove the 'defender' hood letters and go back to the original decal) >>edit, also doesn't have the vents, so yeah ok it appears pumas did come without air con (??) Solved the bowel problem, working on the consonants... |
STC4629 LR rubber mats part number
I will get some pictures up and see if anyone is interested. |
Thank you. I have the mat on the main floor area just not up the sides, I'm guessing it is supposed to come as one? |
yes but you can sale the present one
I am going to try and off set the cost of the new wheels and tyres by selling the current ones, any ideas on how much I should be asking for??
Great stuff. |
Longer studs do exist, but Land Rover and almost everyone using Wolf wheels use the short studs. You bought a car from the factory with Wolf wheels, short studs.
To keep on both sides of the discussion you could buy 4 studs and use one per wheel as a 'safety'
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1646 ![]() ![]() |
No need for longer studs with Wolf wheels...
