Home > My Defender > My first Landrover and plans for it
Page 2 of 4 <1234>
agentmulder
Kuwait
Sorry to drag this off topic, but it might be related if the OP gets wolf wheels...
What torque are you guys pushing on your nuts? Any lube, copper grease etc. on the threads or the er, 'rounded' surface? or just clean and dry ? Solved the bowel problem, working on the consonants...
Post #534406 24th May 2016 9:56pm
Dtfrith
I am going to order the wolf wheels, just need to sort tyres. Would 265/75r16 work on the 6.5 wide rims? Interested to know the answer to above as well.
Post #534434 25th May 2016 6:18am
agentmulder
Kuwait
FWIW (not much?) I had a 235/85 fitted to a LR genuine wolf wheel today and rolling it out and heaving on to the spare carrier gives me a weee bit of insight to this >> I really cant see another 30mm being an issue... Solved the bowel problem, working on the consonants...
Post #534437 25th May 2016 6:23am
Cupboard
If you look at the specs that manufacturers provide for their tyres, the widest you can fit on a 6.5" rim is 255/85.
265/75 asks for a 7".
Not to say it's not possible, people put 235s on the 5.5 steel wheels and that's out of spec too.
Post #534456 25th May 2016 8:10am
On Puma-engined Defenders, aircon was standard only on XS models. On all other models (County and below) a/c was a build-time (factory-fitted) option.
Many, many Pumas do not have aircon.
Post #534477 25th May 2016 8:58am
Dtfrith
After a bit more reading and shopping I now have a list of bits to sell / swap. Eg, I would like to exchange the raised suspension for standard kit. Am I aloud to put up swaps in the sale area??
Post #535975 30th May 2016 8:07pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Just to add, I'm running standard length studs on my wolfs (wolves??). Regards to torque, I honestly have no idea, I did them up fairly tight, had no troubles after a couple of hundred miles Thumbs Up . I did put a load of copper grease on the nuts and studs in the hope they'll come off easy when necessary.
Also to add: As mentioned in other threads, the shorter studs mean the ends are protected by the nuts so the thread doesn't get damaged. Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #535979 30th May 2016 8:24pm
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
From memory on clean dry threads it's something like 110Nm for steels and 130Nm for alloys. Despite all the b*ll*cks I still copper slip my hub mating faces and the threads and yet have never ever had one come loose or even begin to work.
Post #535984 30th May 2016 8:41pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
This wouldn't be the same lany I walked past and had a good look around today parked up just down the road from a chippy? It does look very nice so far Thumbs Up
On the topic of Wolf rims they are to be torqued to 170nm on the Wolf fleet and also the old 90/110 fleet that never had the longer studs fitted, it looked wrong to see a nut with visible threads as the stud did not even come flush. There was as part of the retro fit a small plaque that was riveted into the cab "Wolf rims fitted torque to 170nm"
 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #535990 30th May 2016 9:01pm
K.M
United Kingdom 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
You need a few more posts first Smile think it's 25 or so...
Post #536001 30th May 2016 9:41pm
Dtfrith
Yea that's me, I live opposit where it is parked, give a toot if it's out there the the next time your visiting the chippy 👍🏼
Post #536209 31st May 2016 5:23pm
Dtfrith
Ah right I will have to wait for a bit then, thank you.
Post #536215 31st May 2016 5:32pm
Dtfrith
Can anyone tell me what this is?
Can anyone tell me what this is??
Post #536811 2nd Jun 2016 9:03am
trickster5000
It's the heater outlets I believe. Thumbs Up Matt.
Post #536813 2nd Jun 2016 9:07am
Cupboard
Yes, the knee warmers. If you fiddle around with the heater settings some air should eventually trickle out of them.
Post #536853 2nd Jun 2016 11:15am
Page 2 of 4 <1234>
