Home > In Car Electronics > Where to mount CB radio - Puma dash?
Page 3 of 3 <123
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Markez79 wrote:
Hi,
Could this simply replace where the sunroof would be on an XS model?
Thanks
Mark
NO !
You can't !
This is the console for Defender with sunroof :
https://www.davidecorsetti.com/prodotti.ph...p;id_cat3= Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #801260 7th Nov 2019 7:16pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Thank you!
Almost done, just some extra trimming around the console and the bracket needs to done, then finished.
I ran the cables across the roof / headliner rather than down the A pillars, as I have a set of 5 rocker switches up there, and there was a lot of wiring that need to be hidden.
Pictures to follow once it'd all installed and closed up.
So far, easy to do, just takes time and a lot of patience in measuring and cutting the headliner and making it fit neatly.
Thanks for your advice and help Thumbs Up
Post #801752 11th Nov 2019 12:26pm
MuD have an option for just below the passenger glove box / grab handle.
Might be worth taking a look.
I noticed it the other day. $W33T $0U7H3RN $UG4R
Post #801754 11th Nov 2019 12:36pm
mikeh
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Theater wrote:
Markez79 wrote:
Hi,
Thanks
Mark
NO !
You can't !
Could you use this without a sunroof but put a supporting bracket across the roof? Like the look over the full length one but dont want to put a sunroof in!!!
Post #836172 9th Jun 2020 5:23pm
2010Blackdefender90
Mine is full length, I don’t have a sunroof, you have to remove the middle roof support bracket if you go full length.
It’s a simple job to fit, but time consuming, running cables etc, then cutting the roof liner, mine needs a trim on rear to make it sit flush...
It’s hidden up in the roof, honestly, most people don’t know it’s there until you point at it.
Post #836175 9th Jun 2020 5:34pm
mikeh
Thanks
Other than the light on the rear section, can it be used for anything else?
Post #836178 9th Jun 2020 5:41pm
2010Blackdefender90
CB / Switches / or a radio / you can mod the rear light panel and put in switches there if you want.
I put in a RR P38 light panel with LED’s. Easy plug and play, I now have map reading lights for each side.
Post #836180 9th Jun 2020 5:56pm
2010Blackdefender90
Post #836181 9th Jun 2020 5:56pm
mikeh
Like the light. Have to look out for one. And switches on the blank panel is a good idea especially for ones not used all the time. Saves cutting into the dash which I was looking at, so keeps them up out the way and retain the original look of the dash. If you spray painted the rear section black, it would blend in more with the dark lining. Did you get yours from LRS?
Post #836195 9th Jun 2020 6:50pm
2010Blackdefender90
Yep, he had a few left in stock.
Prefer it silver / stainless, enough black already or it starts to look like the inside of coffin Thumbs Up
Post #836203 9th Jun 2020 7:36pm
Page 3 of 3 <123
