Home > In Car Electronics > Where to mount CB radio - Puma dash? |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
NO ! You can't ! This is the console for Defender with sunroof : https://www.davidecorsetti.com/prodotti.ph...p;id_cat3= Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
7th Nov 2019 7:16pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20477 |
MuD have an option for just below the passenger glove box / grab handle.
Might be worth taking a look. I noticed it the other day. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
11th Nov 2019 12:36pm |
mikeh Member Since: 05 Feb 2015 Location: South Coast Posts: 28 |
Could you use this without a sunroof but put a supporting bracket across the roof? Like the look over the full length one but dont want to put a sunroof in!!! |
9th Jun 2020 5:23pm |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
Mine is full length, I don’t have a sunroof, you have to remove the middle roof support bracket if you go full length.
It’s a simple job to fit, but time consuming, running cables etc, then cutting the roof liner, mine needs a trim on rear to make it sit flush... It’s hidden up in the roof, honestly, most people don’t know it’s there until you point at it. Click image to enlarge Click image to enlarge Click image to enlarge |
9th Jun 2020 5:34pm |
Thanks
Other than the light on the rear section, can it be used for anything else? |
9th Jun 2020 5:41pm |
CB / Switches / or a radio / you can mod the rear light panel and put in switches there if you want.
I put in a RR P38 light panel with LED’s. Easy plug and play, I now have map reading lights for each side. Click image to enlarge |
9th Jun 2020 5:56pm |
Like the light. Have to look out for one. And switches on the blank panel is a good idea especially for ones not used all the time. Saves cutting into the dash which I was looking at, so keeps them up out the way and retain the original look of the dash. If you spray painted the rear section black, it would blend in more with the dark lining. Did you get yours from LRS?
9th Jun 2020 6:50pm |
Yep, he had a few left in stock.
Prefer it silver / stainless, enough black already or it starts to look like the inside of coffin |
9th Jun 2020 7:36pm |
