Home > My Defender > Introduction of my 110
Page 6 of 10 <12345678910>
John Fair
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
Rolling with laughter indeed. It was slightly tongue in cheek. I bought two 1 mtr lengths of 25mm flexi pipe from the boatyard and put one end into the lower heater outlet, the other end in the rear. Job done. Actually quite effective and cost all of �5. Sometimes cheap is the way forward. 👍
Post #585834 17th Dec 2016 5:50pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Haha fair play. Might be worth a try myself and save on the cost of a fuel burning heater 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #585905 17th Dec 2016 9:16pm
JOW240725
Haha, looks slightly better than the guy who use used a Hoover tubes!! Rolling with laughter James
Instagram @suffolk_rovers
Post #585934 17th Dec 2016 10:41pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
John Fair wrote:
Plus some seal removal. Seals are overrated and add weight. Just think of the mpg improvement from the weight saving alone 😂😂😂
Hi John, why have you removed the seals?
Post #586554 20th Dec 2016 3:06pm
John Fair
Hi. I removed the seal to allow oil migration from the axle to the wheel bearings / drive member splines. It's something I have always done but is often open to great debate. From my personal experience the pros out weight the cons.
Pros easier service as no stripping of hubs etc just a standard axle oil change. Never changed a bearing running in oil although I suspect this is down to the effect of the cons.
Cons. Keeping oil contained requires better seal maintainence and inspection. This could actually be a pro not a con as any problems show quickly and you pick up on them. I.e. Drive members working loose shows as oil misting. Rear seals leaking are exactly that and require change. ( again in day to day driving this has never happened and has only occurred very rarely in extreme use)I wonder how many people have grease seals passing unoticed and pressure wash water etc in hence bearing failure.
Hope this helps.
Post #586685 21st Dec 2016 7:01am
Defendermatt
Thanks for the response.
Post #586754 21st Dec 2016 3:33pm
John Fair
Its ok. Gives me something to do on the journey through Europe in the Defender. Yesterday due to a miscalculation on time we had to get a bit footy. Results are pretty consistent to the summer eurotrip. At @90 mph you only get 20mpg. Today's a bit more organised and at @ 60-70 mph were doing 31 mpg. Huge difference and gives a theoretical range of @ 550 miles in a 110 or 350 at full chat
Post #586757 21st Dec 2016 3:42pm
L110CDL
Nice set off figures there John Fair Thumbs Up Clayton.
Keeper.
Post #586853 21st Dec 2016 8:30pm
John Fair
Managed a drive around the Le Mans circuit. The width of the road makes the Defender look really small. 😞
Post #588183 28th Dec 2016 4:38pm
JOW240725
Wow looks great fun... So what was your best time? Rolling with laughter Bow down James
Post #588185 28th Dec 2016 4:40pm
John Fair
24 hours 😂
Post #588359 29th Dec 2016 7:35am
JOW240725
How are you getting on with your diffs? Please with the result? James
Post #598646 2nd Feb 2017 5:49pm
Gutch1985
Loving the pictures pal
Post #598676 2nd Feb 2017 7:46pm
John Fair
Sorry. Been busy with house stuff. The diff is working absolutely fine and has eliminated several issues, the biggest being the reliability of the standard 110 rear or lack of. If your interested in a long nose p38 conversion I should speak to Dave Ashcroft sooner rather than later. I'm sure he could be talked into making you one. Still no update on the suspension. Spring is coming!!!!!!!! ...... see what I did there😂😂😂
Post #598848 3rd Feb 2017 4:09pm
John Fair
Quiet day out.
Post #625878 21st May 2017 8:40pm
