Home > Puma (Tdci) > Nugget Stuff Sealed air intake
Page 1 of 6 123456>
tomdaprince
Netherlands 2007 Defender 90 Puma 2.4 HT Tonga Green
Good morning,
I am considering purchasing the Nugget Stuff Sealed air intake kit from First Four. It says clearly in their add that it's only suitable for a RHD vehicle. The air induction routing is identical on LHD and RHD so can someone shed some light on the possible issues for a LHD?
https://www.firstfour.co.uk/item/2176798/d...ystem--rhd
Post #533133 20th May 2016 8:32am
jst
the way the box is shaped means it wont go on the wing, you would need a mirror image of it.
another alternative is d44 do a plate with a tube welded onto it that the hose then goes onto. similar price. email Jake for details, it wasnt advertised on their website last time i looked. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #533142 20th May 2016 9:06am
jst
found the picture from when i enquired. this goes in side the wing. this is RHD orientated but they can do LHD i believe
jake@devon4x4.com
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #533143 20th May 2016 9:08am
tomdaprince
Hi James,
Thanks for your reply. That would be the case with older vehicles, but on the Puma LHD and RHD have the air inlet on the same spot so that should be the same. Don't believe the heater being there on mine instead of clutch cylinder, brake booster and steering column is an issue either. Have inquired with Nugget Stuff in Australia as well, will share as soon as I receive their answer.
Post #533146 20th May 2016 9:21am
jst
sorry i assumed air intake was on drivers side on LHD too. i have a webasto in mine between the heater and the wing am sure you would get nugget in there.
i have nugget on one of mine, will get the D44 next time, seals better i think. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #533150 20th May 2016 9:54am
tomdaprince
The amount of sealing is exponentially related to the amount of silicone used. haha. I like the Devon one a lot, Nugget seems a lot better value for money though, the Devon is GBP114 incl VAT.
Post #533151 20th May 2016 9:57am
jst
nugget ones seals to the wing, you then seal the snorkel to the other side of the wing.
d44 one you could seal to the snorkel Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #533153 20th May 2016 10:15am
I suspect that the issue may be routing the Nugget components past the heater and heater air intake, which on a LHD vehicle is on the same side as the engine air intake.
Post #533196 20th May 2016 2:45pm
Pickles
Nugget Stuff has an EXCELLENT reputation in Aussie.
Wayne is the owner, an ABSOLUTE GENTLEMAN,..he has a pretty impressive 130.
I'm sure He'd love to speak to anyone, if they had any questions regarding his gear.
Pickles.
Post #533301 20th May 2016 10:03pm
HardCharger
I'm waiting on mine to arrive so I can install my Mantec Plastic Jobbie and make sure it's a true snorkel. Will be raising all my other breathers while I'm at it.
I've been in contact with Wayne and he hasn't mentioned any potential issues for me as I have a LHD truck.
Will keep all y'all posted once the kit arrives.
Post #533324 21st May 2016 4:56am
Cupboard
Is there anything else in a Puma that needs waterproofing? And sensors that don't like getting wet?
I've seen a Disco 2 with a snorkel die after a water crossing because it's electrics threw a wobbly.
Post #533410 21st May 2016 1:40pm
jst
http://www.defender2.net/forum/viewtopic.php?p=491045#491045 Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #534679 25th May 2016 8:32pm
Cupboard
Thumbs Up
Post #534766 26th May 2016 6:56am
HardCharger
Installed the Nugget kit, it's brilliant!
Engine is more quiet and I think I have more power. Still observing though.
So yes, it fits LHD trucks.
Post #546461 6th Jul 2016 7:46am
tomdaprince
Hi HardCharger,
Could to snap some picks for me? As I could not get in in with the heater intake being in the way. Even cut up the heater intake to try to get it to fit an no luck either.
Post #546467 6th Jul 2016 8:15am
Page 1 of 6 123456>
