Home > Puma (Tdci) > Nugget Stuff Sealed air intake |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 |
Good morning,
I am considering purchasing the Nugget Stuff Sealed air intake kit from First Four. It says clearly in their add that it's only suitable for a RHD vehicle. The air induction routing is identical on LHD and RHD so can someone shed some light on the possible issues for a LHD? https://www.firstfour.co.uk/item/2176798/d...ystem--rhd |
20th May 2016 8:32am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8145 |
found the picture from when i enquired. this goes in side the wing. this is RHD orientated but they can do LHD i believe
jake@devon4x4.com Click image to enlarge Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th May 2016 9:08am |
Hi James,
Thanks for your reply. That would be the case with older vehicles, but on the Puma LHD and RHD have the air inlet on the same spot so that should be the same. Don't believe the heater being there on mine instead of clutch cylinder, brake booster and steering column is an issue either. Have inquired with Nugget Stuff in Australia as well, will share as soon as I receive their answer. |
20th May 2016 9:21am |
sorry i assumed air intake was on drivers side on LHD too. i have a webasto in mine between the heater and the wing am sure you would get nugget in there.
i have nugget on one of mine, will get the D44 next time, seals better i think. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th May 2016 9:54am |
The amount of sealing is exponentially related to the amount of silicone used. haha. I like the Devon one a lot, Nugget seems a lot better value for money though, the Devon is GBP114 incl VAT.
20th May 2016 9:57am |
nugget ones seals to the wing, you then seal the snorkel to the other side of the wing.
d44 one you could seal to the snorkel Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th May 2016 10:15am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17526 |
I suspect that the issue may be routing the Nugget components past the heater and heater air intake, which on a LHD vehicle is on the same side as the engine air intake.
20th May 2016 2:45pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 |
Nugget Stuff has an EXCELLENT reputation in Aussie.
Wayne is the owner, an ABSOLUTE GENTLEMAN,..he has a pretty impressive 130. I'm sure He'd love to speak to anyone, if they had any questions regarding his gear. Pickles. |
20th May 2016 10:03pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 742 |
I'm waiting on mine to arrive so I can install my Mantec Plastic Jobbie and make sure it's a true snorkel. Will be raising all my other breathers while I'm at it.
I've been in contact with Wayne and he hasn't mentioned any potential issues for me as I have a LHD truck. Will keep all y'all posted once the kit arrives. |
21st May 2016 4:56am |
Is there anything else in a Puma that needs waterproofing? And sensors that don't like getting wet?
I've seen a Disco 2 with a snorkel die after a water crossing because it's electrics threw a wobbly. |
21st May 2016 1:40pm |
http://www.defender2.net/forum/viewtopic.php?p=491045#491045 Cheers
25th May 2016 8:32pm |
26th May 2016 6:56am |
Installed the Nugget kit, it's brilliant!
Engine is more quiet and I think I have more power. Still observing though. So yes, it fits LHD trucks. |
6th Jul 2016 7:46am |
Hi HardCharger,
Could to snap some picks for me? As I could not get in in with the heater intake being in the way. Even cut up the heater intake to try to get it to fit an no luck either. |
6th Jul 2016 8:15am |
