![]() | Home > Puma (Tdci) > Nugget Stuff Sealed air intake |
WhiskyJackR Member Since: 25 Nov 2014 Location: Lizard Posts: 159 ![]() ![]() |
Hi Guys,
So based on the recommendation from Nosnibod I ordered this from Auto Silicone hoses: http://www.ebay.co.uk/itm/190886536852 Thank's all for input and nugget for explaining the background. Alls well that ends well ![]() ![]() |
Hi Wayne.
Thank you so much, that is a simply awesome example of supplier back up. I can cancel the hose I ordered right away and await the one you've sent together with the fitting. Can I just say a massive thank you. Suppliers like you and the guys on this forum make Defender2.net the best support group bar none. It's like 'Emergency First Respnse' for Landy owners ![]() All the very best ....... Nick Any farther South and I'll need to trade the Defender in for a Landing Craft ![]() |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3788 ![]() ![]() ![]() |
Wayne's (Nugget) response does not surprise me one little bit.
One of the most genuine guys you could ever meet, He has an absolutely 100% record for customer service & honesty in Aussie!!..Check out his website. Pickles. |
KU310R Member Since: 16 May 2017 Location: Private Posts: 30 ![]() ![]() |
This is my first time posting here. I have installed the Nugget sealed air intake this week on my 2012 2.2 90 and was really satisfied with the quality of the components and service from firstfour. However after less than a week the bolt head on the alternator bracket tore through the pipework and I contacted Wayne through his website for any possible solutions regarding the new fitting he made for the 2.2. He replied to me on the same day and offered to send me a new updated version. That's best customer service I have ever received! Will definitely recommend his products...and keep checking any new stuff for myself! |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
So do you now receive the updated and correct set up from First Four or not? Wouldn't want to buy and fit this and then need another hose after? 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
I emailed Wayne and he sent me the replacement part even though I had originally ordered it from firstfour website. In your case you can gie either of them a call so you can decide which part is best for you.
All I can say is that the products are all of top quality & service has been great from firstfour & Wayne himself! |
nugge t Member Since: 03 Apr 2014 Location: Brisbane Posts: 50 ![]() ![]() |
Hi all,
I am currently waiting for First Four to let me know how many kits they have in stock and I will send the new adaptors to them so that all kits can be supplied with the new part. Cheers |
Hi guys, after driving it in town for the first time after installing the nugget kit and doing modifications to the airbox by removing "fan" and cutting extruding pipework into the airbox I can confirm the benefits are well worth it!
The car feels much smoother to drive and is able to keep moving smoothly at lower speeds where before I had to drop a gear. Great product! |
I can confirm that all kits supplied by First Four will have the new adaptor and also the Black hose.
Just thought I might also mention that if you are looking to complete the water sealing, I do Diff Breather Manifold Kits which are designed specifically for Defenders and machined from solid ally billet, have top quality sintered stainless steel breathers and as far as I know, are the only kits where each port is identified. FD for front Diff, RD for Rear Diff, TC for Transfer Case, Fuel for the fuel Tank and GB for the Gear Box. The 4 port does FD, RD, TC and Fuel. The 5 Port does FD, RD, TC, Fuel and GB. ![]() You can read more about them on my web page [/img]http://www.nuggetstuff.com/product/defender-5-port-diff-breather-manifold-kit/[url] [/url] |
Mine arrived today and with all the modified bits in the box
![]() Question, if I have already removed the old plastic air intake when doing the intercooler, do I need to drop the inner guard? 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
you should only need to remove the strip of guard which incorporates the flare to be able to slide the new air box into position.
cheers |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Fitted mine 2 years ago, Will agree, the clearance is close,, Reading above, has the offset fitting been modified ??, to give some more clearance ?? Best i check it tomorrow ? Picture taken when fitted from a a different angle ![]() Click image to enlarge LOL, as someone already made comment that blue sealer gets everywhere !!!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Thanks ![]() 1995 110 300TDI 1995 90 300TDI |
