Home > Puma (Tdci) > BAS or Alive for EGR and Rev Hang? |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1640 |
Having done quite a bit of driving in the last month, I am at the point where the "rev hang' is really annoying me now!
Also, over the last 200 miles, on shut down my EGR valve is chuffing away like the Flying Scotsman! Time for a re-map! Lots on here have had one done using either Alive or BAS so I would really appreciate advice if either or both options; 1: Get rid of the 'rev hang' between gear changes 2: Close off the EGR valve... with all the benefits associated! Many thanks, Pete YOLO... You Only Live Once... |
8th May 2016 1:01am |
I have read up on here about the EGR issue... sorted then!
So, does the re-map get rid of the 'Rev hang' please? YOLO... You Only Live Once... |
8th May 2016 10:19am |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
I'm not sure what Rev hang is ...? Are you meaning a flatspot ?
8th May 2016 10:49am |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2634 |
my understanding, they can tune it out.. and get rid of the flatspots alive would be my personal choice |
8th May 2016 10:57am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20119 |
Alive for me too, definitely on the EGR front.
8th May 2016 11:55am |
The RPM stays UP when you take your foot off the accelerator and depress the clutch to change gear. It usually 'hang's for 1-2 seconds before dropping down to idle. LOTS on here about it... http://www.defender2.net/forum/topic42524.html?highlight=rev+hang Apparently it is designed to smooth out gear changes and reduce 'backlash'. Personally I loath it! So if either Alive or BAS have modded their respective 'map' to also remove the 'feature', that would be what I would be looking for... Surely someone on here who has either of these 'tunes' would be able to advise... please... Cheers! YOLO... You Only Live Once... |
8th May 2016 11:57am |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Another happy Alive customer, Gary tweaked my map a couple if times to tailor it to my exact needs, brilliant service 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
8th May 2016 8:33pm |
integrale Member Since: 29 Oct 2015 Location: Auckland Posts: 77 |
BAS 150bhp ecu upgrade fitted. Rev hang (previously a real pain) now gone.
8th May 2016 10:25pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2623 |
Anyone else have the 'kangaroo' effect in 1st low with the BAS remap? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
9th May 2016 9:15am |
GAZ59 Member Since: 10 Feb 2015 Location: DARWIN Posts: 3 |
I have the same problem as you do Pete . Does any one know of any place in Australia that does remaps?
Cheers Garry |
10th May 2016 3:09am |
