Home > Puma (Tdci) > BAS or Alive for EGR and Rev Hang?
YOLO110
Australia
Having done quite a bit of driving in the last month, I am at the point where the "rev hang' is really annoying me now!
Also, over the last 200 miles, on shut down my EGR valve is chuffing away like the Flying Scotsman!
Time for a re-map!
Lots on here have had one done using either Alive or BAS so I would really appreciate advice if either or both options;
1: Get rid of the 'rev hang' between gear changes
2: Close off the EGR valve... with all the benefits associated!
Many thanks,
Pete Smile YOLO... You Only Live Once...
Post #529873 8th May 2016 12:01am
YOLO110
Australia
I have read up on here about the EGR issue... sorted then!
So, does the re-map get rid of the 'Rev hang' please? Rolling Eyes YOLO... You Only Live Once...
Post #529910 8th May 2016 9:19am
Anderzander
I'm not sure what Rev hang is ...? Are you meaning a flatspot ?
Post #529918 8th May 2016 9:49am
Likeomg
my understanding, they can tune it out.. and get rid of the flatspots alive would be my personal choice
Post #529920 8th May 2016 9:57am
Alive for me too, definitely on the EGR front.
Post #529925 8th May 2016 10:55am
YOLO110
Australia
The RPM stays UP when you take your foot off the accelerator and depress the clutch to change gear. It usually 'hang's for 1-2 seconds before dropping down to idle.
LOTS on here about it... Rolling Eyes
http://www.defender2.net/forum/topic42524.html?highlight=rev+hang
Apparently it is designed to smooth out gear changes and reduce 'backlash'. Personally I loath it!
So if either Alive or BAS have modded their respective 'map' to also remove the 'feature', that would be what I would be looking for... Thumbs Up Thumbs Up
Surely someone on here who has either of these 'tunes' would be able to advise... please... Neutral
Cheers! YOLO... You Only Live Once...
Post #529926 8th May 2016 10:57am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
BAS & rev hang ...
Recently installed the BAS170.
Rev hang is still there - but an email to BAS may ascertain whether it can be "tuned out".
On the BAS app via the Bluetooth dongle: the "commanded EGR flow" shows up as zero - so EGR may well be electronically closed.
Post #529995 8th May 2016 7:17pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Another happy Alive customer, Gary tweaked my map a couple if times to tailor it to my exact needs, brilliant service Thumbs Up Thumbs Up 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #529998 8th May 2016 7:33pm
integrale
New Zealand
BAS 150bhp ecu upgrade fitted. Rev hang (previously a real pain) now gone.
Post #530025 8th May 2016 9:25pm
Naks
Anyone else have the 'kangaroo' effect in 1st low with the BAS remap? --
Post #530051 9th May 2016 8:15am
GAZ59
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I have the same problem as you do Pete . Does any one know of any place in Australia that does remaps?
Garry
Post #530315 10th May 2016 2:09am
