Home > Wheels & Tyres > The plastic bit that holds the centre of the spare wheel ...
pjh
Hello All,
I'm after the name of (and preferably the part number of) the plastic bit that holds the centre of the spare wheel against the bulkhead in a pick-up. I've searched, but to no avail. I've got the bracket with bolt, but no centre retaining part.
Many thanks,
Peter Defender 11MY USW
Post #46861 30th Nov 2010 11:36pm
which piece do you mean? there is a metal disc and a metal "bar" thing, but i can't imagine they'd be plastic... not strong enough.
part #7 "clamp", MXC5477 �8.33
#8 "disc, clamping-spare wheel" BTR335 removed from service (same as used on the rangie classic i think though, and camel discos/defenders to hold the sand channel stuff onto the roofracks)
#9 "washer,plain" WA116106 �2.39
#10 "spacer" KTD500070 �4.12
#11 "nut, alloy road wheel" RRD500560 �1133
#12 "nut, 16mm, wheel retention" RRD500010 �1.67
Post #46876 1st Dec 2010 8:45am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I prefer not to use that and put the bolt through one off the wheel nut holes so the tyre is sitting off-center and I just can place a jerry-can next to the tyre. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #46888 1st Dec 2010 9:50am
pjh
Brilliant ! Thanks guys. I meant the metal disk and bar - I had been told that it was one piece and plastic.
Many thanks,
Post #46893 1st Dec 2010 10:26am
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
I think you're right that it's a one piece Peter (although it's definitely metal) - it's either a disc or a bar depending on your wheels. Mine came with alloys, and had the disc. I had the bar-style on my old series 2A, and that fits steel wheels (larger center hole than alloys). Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #46935 1st Dec 2010 3:07pm
roel
The disc also works on steel rims as with the Camel Trophy the spare tyre on the roof was held down with it. Roel
Post #46984 1st Dec 2010 8:11pm
