Home > Wheels & Tyres > The plastic bit that holds the centre of the spare wheel ... |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6119 |
which piece do you mean? there is a metal disc and a metal "bar" thing, but i can't imagine they'd be plastic... not strong enough.
Click image to enlarge part #7 "clamp", MXC5477 £8.33 #8 "disc, clamping-spare wheel" BTR335 removed from service (same as used on the rangie classic i think though, and camel discos/defenders to hold the sand channel stuff onto the roofracks) #9 "washer,plain" WA116106 £2.39 #10 "spacer" KTD500070 £4.12 #11 "nut, alloy road wheel" RRD500560 £1133 #12 "nut, 16mm, wheel retention" RRD500010 £1.67 |
1st Dec 2010 7:45am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I prefer not to use that and put the bolt through one off the wheel nut holes so the tyre is sitting off-center and I just can place a jerry-can next to the tyre. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
1st Dec 2010 8:50am |
pjh Member Since: 22 Nov 2010 Location: West Yorkshire Posts: 126 |
Brilliant ! Thanks guys. I meant the metal disk and bar - I had been told that it was one piece and plastic.
Many thanks, Peter Defender 11MY USW |
1st Dec 2010 9:26am |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
I think you're right that it's a one piece Peter (although it's definitely metal) - it's either a disc or a bar depending on your wheels. Mine came with alloys, and had the disc. I had the bar-style on my old series 2A, and that fits steel wheels (larger center hole than alloys). Peter
2008 SWB Truck Cab 1952 80" Soft top |
1st Dec 2010 2:07pm |
The disc also works on steel rims as with the Camel Trophy the spare tyre on the roof was held down with it. Roel
1st Dec 2010 7:11pm |
