Home > Maintenance & Modifications > Callipers Rebuild. Tips fitting piston seal retaining ring? |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
cc Changed half shafts today with Bearmach, they were a good price from Hunters Land Rover. They're a hard thing to judge by examination by eye but sounded good (heat treated steel has a certain ring when it's hardened and tempered) so fingers crossed. I started with nothing and still have most of it left! |
6th May 2016 5:27pm |
danridge Member Since: 28 May 2013 Location: Bath Posts: 438 |
have you got rid of the clunk when changing gear, reversing, going forward etc? Given how smoothly my brake pads change went (a.k.a. a full caliper rebuild ) it would just about be my luck that it's not just the half shafts but teeth on the diff too
Have you got a link to the half shafts that you bought? Cheers, Dan. |
7th May 2016 6:51am |
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...Swe7BWxKbZ
The drive is really quite good as the half shafts were the last link in the chain to be replaced, after bushes, UJ's, A frame ball joint etc. I started with nothing and still have most of it left! |
7th May 2016 10:58am |
ooh - he giveth hope and he taketh away again
You never know, it could just be my half shafts... You've been busy! |
10th May 2016 9:37pm |
It's all about making it better than when it was new. To be fair mines an early model Puma and they seem to be very good or exactly the opposite, Land Rover don't appear to believe in mediocrity. The drive line in particular has improved dramatically with a quite pleasant gear change now, I'm surprised how much the slack and backlash affected the gear selection. The other thing to affect the gear change was using BP ultimate fuel and Millers Eco-boost additive, because the engine revs more freely at lower speeds it has improved the gear change a fair bit, a welcome side effect. Like most on the forum we do it as a labour of love and provided SWMBO doesn't get too rattled then it keeps us out of trouble. I started on the spanners in1965 and sadly a lot of stuff is just too heavy on the Defender for me now, I'm never going to attempt to take another transfer box out on my own that I do know, but I still "enjoy" keeping my hand in. I started with nothing and still have most of it left!
11th May 2016 5:32pm |
