Home > Camping, Caravanning and Holidays > Towball cycle carrier
Teegee
England 2015 Defender 90 Puma 2.2 Landmark LE Montalcino Red
Does anyone have any experience or can recommend a towball mounted cycle carrier to take two mountain bikes,my main concern is getting enough clearance past the spare wheel,any advice great fully received.
Post #523627 13th Apr 2016 12:19pm
simon67
England 2004 Defender 90 Td5 HT Rutland Red
Pendle - do one for the defender
Post #523630 13th Apr 2016 12:27pm
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
I have a Pendle one for 4 bikes. Clears the spare wheel easily. Got it second hand from eBay.
Post #523635 13th Apr 2016 12:44pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Have a look at the maxxraxx stuff. They do one specifically designed to clear the wheel. I use one occassionally and it works very well 2002 110 td5
Post #523636 13th Apr 2016 12:45pm
djgg
Hi Teegee,
I have in my garage a tow bar cycle carrier. I have never used it. You are welcome to come and have a look at it and see if its any use. I live in Southport so not far from you. As for cost a donation to the forum is fine.
David.
Post #523669 13th Apr 2016 4:33pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Very generous by David Bow down Thumbs Up
Post #523706 13th Apr 2016 6:09pm
rockhound42
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
+1 for maxxrax, very robust.
Post #523897 14th Apr 2016 1:27pm
Teegee
Thanks everyone for there help and advice,I knew I had come to the right place Very Happy
Post #524069 14th Apr 2016 10:03pm
SingletrackFred
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Pendle is good, I have one, but be cautious about the bikes rubbing. I use pipe lagging to protect them.
Post #525927 22nd Apr 2016 12:02pm
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
+ 1 maxxraxx. Mine is for 5 bikes.
I use it with 4. And tow a trailer tent
This summer it is going to Italy.
Fabio
Post #526017 22nd Apr 2016 4:34pm
Dasher
2015 Defender 110 Puma 2.2 USW Santorini Black
I used a Pendle one on all of my Disco 2s. Separate the bikes with the folding foam things from Decathlon.http://www.decathlon.co.uk/bike-frame-protector-cycle-carrier-accessory-id_684933.html
Mine's nominally a four bike carrier but generally only had two on it. I used to put one of the Decathlon things on first to give the innermost bike something to sit up against and I used to use two of these between the bikes to space them out nicely.
They are absolutely first class and store easily when not in use.
Be careful though and make sure that you get a Defender specific one as it has a unique offset. My Disco 2 one will not clear the wheel on a 110 - and that is the reason that mine is currently on Ebay. There are a couple of different models as they changed over the years - mine is the square section type - roughly 30mm - useful if you want to space the tow ball out at the same time. The current model doesn't set the ball out as far.
Post #526793 25th Apr 2016 9:37pm
CarlS
2016 Defender 110 Puma 2.2 XS CSW Aintree Green
I borrowed a friends Thule towball mount bike carrier the other day. I was dubious about just mounting it on the ball but it worked great!!
I took the number plate off for the photo..... Embarassed The spawn of AndrewS
2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead
2016 Mini Countryman Cooper S All 4
2019 BMW R1200 GSA Rallye Sport
Post #526951 26th Apr 2016 1:10pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Does that Thule tilt allowing access to the rear door?
They are cheap and plentiful on ebay so constantly tempted... Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #526966 26th Apr 2016 2:16pm
CarlS
Yes it tilts, bit of a pain to reach the wing nuts that hold the tilt facility in place though. The spawn of AndrewS
Post #527334 27th Apr 2016 3:54pm
markj1878
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Corris Grey
Maxxraxx Thumbs Up
Post #527339 27th Apr 2016 4:19pm
