![]() | Home > Camping, Caravanning and Holidays > Towball cycle carrier |
simon67 Member Since: 18 Jun 2015 Location: west sussex Posts: 569 ![]() ![]() ![]() |
Pendle - do one for the defender
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 ![]() ![]() ![]() |
I have a Pendle one for 4 bikes. Clears the spare wheel easily. Got it second hand from eBay.
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Have a look at the maxxraxx stuff. They do one specifically designed to clear the wheel. I use one occassionally and it works very well 2002 110 td5
djgg Member Since: 22 Apr 2013 Location: Southport Posts: 22 ![]() ![]() |
Hi Teegee,
I have in my garage a tow bar cycle carrier. I have never used it. You are welcome to come and have a look at it and see if its any use. I live in Southport so not far from you. As for cost a donation to the forum is fine. David. |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Very generous by David
rockhound42 Member Since: 24 Jun 2015 Location: where Surrey meets Sussex Posts: 38 ![]() ![]() ![]() |
+1 for maxxrax, very robust.
Teegee Member Since: 12 Feb 2016 Location: St Helens Posts: 36 ![]() ![]() ![]() |
Thanks everyone for there help and advice,I knew I had come to the right place
SingletrackFred Member Since: 23 Mar 2015 Location: Reading Posts: 66 ![]() ![]() ![]() |
Pendle is good, I have one, but be cautious about the bikes rubbing. I use pipe lagging to protect them.
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
+ 1 maxxraxx. Mine is for 5 bikes.
I use it with 4. And tow a trailer tent This summer it is going to Italy. Fabio |
Dasher Member Since: 12 Nov 2012 Location: Nottingham Posts: 31 ![]() ![]() |
I used a Pendle one on all of my Disco 2s. Separate the bikes with the folding foam things from Decathlon.http://www.decathlon.co.uk/bike-frame-protector-cycle-carrier-accessory-id_684933.html
Mine's nominally a four bike carrier but generally only had two on it. I used to put one of the Decathlon things on first to give the innermost bike something to sit up against and I used to use two of these between the bikes to space them out nicely. They are absolutely first class and store easily when not in use. Be careful though and make sure that you get a Defender specific one as it has a unique offset. My Disco 2 one will not clear the wheel on a 110 - and that is the reason that mine is currently on Ebay. There are a couple of different models as they changed over the years - mine is the square section type - roughly 30mm - useful if you want to space the tow ball out at the same time. The current model doesn't set the ball out as far. |
CarlS Member Since: 10 Apr 2007 Location: Probably near you Posts: 148 ![]() ![]() |
I borrowed a friends Thule towball mount bike carrier the other day. I was dubious about just mounting it on the ball but it worked great!!
![]() Click image to enlarge I took the number plate off for the photo..... ![]() 2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead 2016 Mini Countryman Cooper S All 4 2019 BMW R1200 GSA Rallye Sport |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 723 ![]() ![]() ![]() |
Does that Thule tilt allowing access to the rear door?
They are cheap and plentiful on ebay so constantly tempted... Instagram: L90andy My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
Yes it tilts, bit of a pain to reach the wing nuts that hold the tilt facility in place though. The spawn of AndrewS
markj1878 Member Since: 06 May 2015 Location: Liverpool Posts: 56 ![]() ![]() ![]() |
Maxxraxx
