Home > Technical > Some advice on clutch issue MY15 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17526 |
More likely to be the well known driven plate spring problem, get the clutch replaced under warranty without delay.
18th Mar 2016 11:14pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
agree sounds like the clutch plate springs mine got noisey at about same mileage changed at 11k little worrying that a 15 plate possibly has this issue as I was hoping that my new plate would be better than original one as it was replaced in 2014 DEFENDER 90 TDCI XS,
19th Mar 2016 6:34am |
ChrisJ Member Since: 12 Nov 2013 Location: Warwickshire Posts: 231 |
Thank you both for the replies.
I have booked her in for the week after next so I will report back with the outcome. I must admit I have been pleasantly surprised that this is the first thing I've needed to call on the dealer for in nearly a year since buying her, it's a shame it could be a big one. Will keep you updated. |
19th Mar 2016 7:01pm |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 719 |
I'd be interested to hear what the garage says for a car so young. I thought that the clutch had been upgraded so your first prognoses could be correct.
Cheers N |
25th Mar 2016 6:23am |
If it's the driven plate springs, can you ask them to keep it for you to see, take a few photos and post up here.
Will be interesting to see which type has been fitted. |
25th Mar 2016 1:10pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
Interesting, my 65reg is just past 5500miles and has just started to have a slight rattle when cold (that goes when clutch peddle depressed)... so very similar mileage. I will be interested how you get on. |
25th Mar 2016 9:07pm |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
mine has a rattle when neutral.
if I put transfer case to neutral and in 6th gear (vehivle stationary), the rattle gets really loud. are we talking about the same thing here? cheers |
24th Apr 2016 1:08am |
I couldn't make my original booking at the dealer to have this looked at, I have rebooked for this Thursday (28th) so I will update accordingly once the 90 has been looked at.
The rattle is getting progressively worse now with notchy gear selection also. |
24th Apr 2016 2:32pm |
An update for anyone interested in my clutch issue.
I had the defender in for the first service today and the inspection on the clutch issue. They have confirmed a new clutch is required due to broken springs on the clutch plate, to be replaced under warranty at the end of may. I did enquire as to what type of clutch would be used, ie updated or standard, I was told that no technical bulletin had been issued with regards to a known fault with defender clutch but land rover may now be using a new type or updated clutch if they no of an issue. So booked in for the 31st May, new clutch and new seals to my sliding window on the passenger side. The dealer has been very good so far, highly recommend Sturgess Leicester. |
28th Apr 2016 9:36pm |
thanks for the update!
Mine will be go in next tuesday. just out of curiosity whats wrong with the seal? Cheers |
30th Apr 2016 8:43am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2532 |
My 2015 90SW with 4800 miles on the clock has just started to rattle when cold. It's already booked in for first service 2nd week in May so I'll get them to check it. Defender 90XS SW
30th Apr 2016 3:33pm |
I've had a rattling window for a few months now, dealer has looked into it and agreed it is excessive, I believe they are having a glazer visit when my clutch is fitted to try and resolve the issue with new seals. |
2nd May 2016 8:24pm |
Yes very funny - "I've had a rattling window and the dealer is LOOKING INTO IT". Defender 90XS SW
2nd May 2016 8:26pm |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
...and the dealer says "its clear where the problem is, but its a pane to fix".... 1998 Tdi 90 SW,
2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
3rd May 2016 4:50am |
