Home > Technical > Some advice on clutch issue MY15
ChrisJ
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi guys, wondering if I could ask for some advice.
My newish (15 plate) 90 has developed a very rattly clutch, especially when the engine/gearbox is cold, I believe it to be the release/thrust bearing as the noise disappears once the clutch is pressed down.
90 has covered 8k now and there are a couple of niggles on the list to be sorted out by the dealer.
I'm wondering if anyone can give me some advice as to what the problem is but also what I can or should expect from the dealer when it goes in. The rattle has been present for about 1500miles now and is progressively getting louder.
Many thanks
Chris
Post #515882 18th Mar 2016 9:47pm
More likely to be the well known driven plate spring problem, get the clutch replaced under warranty without delay.
Post #515903 18th Mar 2016 11:14pm
LR90XS2011
agree sounds like the clutch plate springs mine got noisey at about same mileage changed at 11k little worrying that a 15 plate possibly has this issue as I was hoping that my new plate would be better than original one as it was replaced in 2014 DEFENDER 90 TDCI XS,
Post #515915 19th Mar 2016 6:34am
ChrisJ
Thank you both for the replies.
I have booked her in for the week after next so I will report back with the outcome.
I must admit I have been pleasantly surprised that this is the first thing I've needed to call on the dealer for in nearly a year since buying her, it's a shame it could be a big one.
Will keep you updated.
Post #516027 19th Mar 2016 7:01pm
nidge n
I'd be interested to hear what the garage says for a car so young. I thought that the clutch had been upgraded so your first prognoses could be correct.
N
Post #517592 25th Mar 2016 6:23am
If it's the driven plate springs, can you ask them to keep it for you to see, take a few photos and post up here.
Will be interesting to see which type has been fitted.
Post #517672 25th Mar 2016 1:10pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Re: Some advice on clutch issue MY15
Many thanks
Chris
Interesting, my 65reg is just past 5500miles and has just started to have a slight rattle when cold (that goes when clutch peddle depressed)... so very similar mileage. I will be interested how you get on.
Post #517797 25th Mar 2016 9:07pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
mine has a rattle when neutral.
if I put transfer case to neutral and in 6th gear (vehivle stationary), the rattle gets really loud.
are we talking about the same thing here?
cheers
Post #526331 24th Apr 2016 1:08am
ChrisJ
I couldn't make my original booking at the dealer to have this looked at, I have rebooked for this Thursday (28th) so I will update accordingly once the 90 has been looked at.
The rattle is getting progressively worse now with notchy gear selection also.
Post #526436 24th Apr 2016 2:32pm
ChrisJ
An update for anyone interested in my clutch issue.
I had the defender in for the first service today and the inspection on the clutch issue.
They have confirmed a new clutch is required due to broken springs on the clutch plate, to be replaced under warranty at the end of may.
I did enquire as to what type of clutch would be used, ie updated or standard, I was told that no technical bulletin had been issued with regards to a known fault with defender clutch but land rover may now be using a new type or updated clutch if they no of an issue.
So booked in for the 31st May, new clutch and new seals to my sliding window on the passenger side.
The dealer has been very good so far, highly recommend Sturgess Leicester.
Thumbs Up
Post #527655 28th Apr 2016 9:36pm
tuesdayfox
thanks for the update! Very Happy
Mine will be go in next tuesday.
just out of curiosity whats wrong with the seal?
Post #528008 30th Apr 2016 8:43am
discomog
My 2015 90SW with 4800 miles on the clock has just started to rattle when cold. It's already booked in for first service 2nd week in May so I'll get them to check it. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #528102 30th Apr 2016 3:33pm
ChrisJ
I've had a rattling window for a few months now, dealer has looked into it and agreed it is excessive, I believe they are having a glazer visit when my clutch is fitted to try and resolve the issue with new seals.
Post #528645 2nd May 2016 8:24pm
discomog
Yes very funny - "I've had a rattling window and the dealer is LOOKING INTO IT". Defender 90XS SW
Morgan Plus 8
Post #528646 2nd May 2016 8:26pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
...and the dealer says "its clear where the problem is, but its a pane to fix".... Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #528704 3rd May 2016 4:50am
