Home > Maintenance & Modifications > Fitting Puma bonnet to TD5
HossBog
I've just purchased an oem Puma bonnet from LRspares (they were cheapest for orm steel).
Can I use my existing TD5 hinges and bonnet catch/striker when fitting the Puma bonnet to my TD5? Ie is just a case of unbolt the TD5 bonnet, move the release catch/cable over to the Puma bonnet and fit?
I know it's rarely that simple.... 2002MY Defender 90 H/T
Post #514975 16th Mar 2016 4:35pm
gilarion
They fit straight on nothing needed, though I would buy new plastic hinge inserts as they are so cheap.
The only thing you may find and I have come across this a couple of times, is that the hinges on the TD5 bulkhead can be a little low so the bonnet rubs against any wing top chequer plate you have fitted, but you can glue a little bit of rubber to the inside edge bottom of the bonnet to avoid the paint rubbing and rusting the metal. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #515012 16th Mar 2016 6:19pm
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
The only difference I found were the two adjustable height bump stops either side of the bonnet. The thread is much smaller on the puma bonnet. Had to use other bolts and put rubber end on them.
Post #515039 16th Mar 2016 7:12pm
SGH
I fitted one to my 300tdi and had to move header tank don't know if TD5 one is in same place.
 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #515064 16th Mar 2016 8:02pm
landybear
United Kingdom 2003 Defender 90 Td5 HT Belize Green
Make sure you get some security hinges so that it stays in place!! Thumbs Up 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous)
Disco 2 Landmark 2004, 2001, 2002 (Previous)
Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous)
Defender 110 300tdi 1993 (Previous)
Range Rover Vogue 4.6 - 2001 (Previous)
Freelanders TD4 (2001 3 door & 2002 5 door) Previous
90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others
Post #515068 16th Mar 2016 8:04pm
HossBog
Thanks everyone! Thumbs Up 2002MY Defender 90 H/T
Post #515131 16th Mar 2016 10:20pm
