![]() | Home > Maintenance & Modifications > Fitting Puma bonnet to TD5 |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
They fit straight on nothing needed, though I would buy new plastic hinge inserts as they are so cheap.
The only thing you may find and I have come across this a couple of times, is that the hinges on the TD5 bulkhead can be a little low so the bonnet rubs against any wing top chequer plate you have fitted, but you can glue a little bit of rubber to the inside edge bottom of the bonnet to avoid the paint rubbing and rusting the metal. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
consumerize Member Since: 27 May 2014 Location: Berkshire Posts: 121 ![]() ![]() ![]() |
The only difference I found were the two adjustable height bump stops either side of the bonnet. The thread is much smaller on the puma bonnet. Had to use other bolts and put rubber end on them.
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
I fitted one to my 300tdi and had to move header tank don't know if TD5 one is in same place.
![]() Click image to enlarge 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
landybear Member Since: 18 Oct 2015 Location: Tamworth & Worcester Posts: 134 ![]() ![]() ![]() |
Make sure you get some security hinges so that it stays in place!!
![]() 2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
HossBog Member Since: 22 Jul 2015 Location: Glos Posts: 131 ![]() ![]() |
Thanks everyone!
