![]() | Home > Puma (Tdci) > Who has lifted the Puma? |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 ![]() ![]() ![]() |
I did by, 2inches, then put it back to standard. The prop shaft (front ) binds up and will destroy the transfer box bearings. Lots of owners here have had issues with Puma lift and Land Rover won't cover warranty issues caused by lifting them. If you don't change the prop shaft, and its still under warranty, don't lift it.
Allan Last edited by Allan on 14th Nov 2010 7:37am. Edited 1 time in total |
i tried but my defender is simply too heavy
Very good ![]() ![]() ![]() Allan |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Why do you want to lift it?
Is there a need or just fancy a change? Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
With the D44 bumper and Warn PowerPlant winch bolted to the front, the front sits low so I give my pumas a 2" lift. However in reality the lift ends up being about 1". I also change the front prop with a wide angle one.
TBH the standard prop could be machined with a small grinder to allow a bit more movement in the UJ. 130's have feeling's as well you know ![]() |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
You did not try hard enough!! ![]() 90 V8 SOFT TOP |
I have a 2 half" lift with no problems.....still on the standard props no binding
I have an ARB bar and winch, and loads of other bits on my SVX and because of the front droop use 130 Land Rover front springs with OME shocks. I have found this the way to go on the front, and Land Rover Australia don't mind.. I have a draw system and tow a boat and carry lots of weight so on the rear I use hduty springs with dislocation cones and terra firma +2 inch shocks. I removed the sway bars/anti roll bars, and I also have an ARB airlocker to use when it hard work to pull the boat out on the beach. Allan |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
2" lift all round, OME shocks and springs, rears on medium rate springs, front on standard rate. No sign of front or rear prop shaft binding. Am told that it can vary from truck to truck whether you'll get a problem with the props and 2" lift - go any higher and more likely. I'll probably go for a double cardon front prop at some stage- probably once the transfer box is shagged
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 ![]() ![]() ![]() |
You must focus your strength grasshopper! ![]() IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4736 ![]() ![]() |
Before I even attempt to lift the Puma, I always ask the wife to get out first. 1982 88" 2.25 diesel
1" From OME
2" Rear OME Sits nice and Level now |
2" front and rear. front on cones, rear on blocks with extra internal spring. sits level when fully loaded and still drives like it's empty. aux springs only come into play when heavily loaded. terra firma big bore shocks all round, outstanding.
Mike any pics of the extra internal spring and what they are cheers Karl
