Home > Puma (Tdci) > Dashboard |
draymond Member Since: 07 Apr 2009 Location: Sydney Posts: 49 |
It's pretty easy to remove the centre stack, if you have a torx screwdriver (the two screws in the HVAC cluster). Theyre' all you need to remove.
You should be able to just gently pull the top (above the vents) of the stack towards you and the clips that hold it in place will pop free. Otherwise, you can probably put your arm up through the passenger side (Assuming, RHD. I don't have a LHD Car) access panel, depending on the thickness of your forearm, you should be able to just reach the cables. |
12th Nov 2010 2:48am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
I found removing the speedo binnacle gave me the access required
12th Nov 2010 7:48am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
I did this and it worked a treat. Pop the dash out a little, slide the radio into place and then arrange the wires as you pop the dash back in. Glyn |
12th Nov 2010 10:13am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Speedo out is very simple 130's have feeling's as well you know
12th Nov 2010 1:02pm |
