Home > Puma (Tdci) > Dashboard
baldylocks
1996 Defender 90 300 Tdi HT Stornoway Grey
Dashboard
Evening all, I've just fitted a replacement Alpine head unit which has a lot of wires hanging out of the back (iPod, Bluetooth unit and leads for sub) which have made it a tad snug trying to get the unit into the dash. There seems to be plenty of space there to accomodate the extra cable but I need to be able to feed it into the space as I push the head unit back in.
Is there an easy way (or a hard one!) get the panel off that has the clock in it or one of the side panels so I can get my hand in to guide the wire?
Many thanks, Gerry
Post #45002 12th Nov 2010 12:45am
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
It's pretty easy to remove the centre stack, if you have a torx screwdriver (the two screws in the HVAC cluster). Theyre' all you need to remove.
You should be able to just gently pull the top (above the vents) of the stack towards you and the clips that hold it in place will pop free.
Otherwise, you can probably put your arm up through the passenger side (Assuming, RHD. I don't have a LHD Car) access panel, depending on the thickness of your forearm, you should be able to just reach the cables.
Post #45003 12th Nov 2010 2:48am
I found removing the speedo binnacle gave me the access required
Post #45007 12th Nov 2010 7:48am
Glynparry25
I did this and it worked a treat. Pop the dash out a little, slide the radio into place and then arrange the wires as you pop the dash back in.
Glyn Sheep
Post #45017 12th Nov 2010 10:13am
AndrewS
Speedo out is very simple Thumbs Up 130's have feeling's as well you know Smile
Post #45032 12th Nov 2010 1:02pm
