Home > Tdi > Serial number question
pablococito
So I bought an engine a while back and the serial number looks like it has been re stamped to RN002200A.
Anyone know where it's from??
Thanks!
Pablo
Post #510201 3rd Mar 2016 5:43am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Have you asked the person you bought it from?
What engine is it supposed to be diesel/petrol/V8/Tdi/Td5/etc? Is it even from/for a Landrover?
If you gave a bit more info then I am sure someone on the forum might recognise it and a picture speaks a thousand words so a good shot of the engine would also help.
All you have given us so far is 'I have an engine, can you guess what it is?'
Post #510248 3rd Mar 2016 9:36am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
My 300Tdi engine was replaced under warranty and has a serial number starting with 2B2B.
Might be worth checking out.
Post #510275 3rd Mar 2016 11:01am
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
Maybe it has been rebored/ reconditioned, repairede etc and restamped R= Recon?
Just a thought,
i dont know why you would restamp an engine block, noone would go to the trouble, unless its a recon company keeping their own register of reconned engines, but then why not use the original numbers? maybe its from an insurance write off or something> ?
has the old number been removed? very suspect if it has... My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #510289 3rd Mar 2016 11:34am
pablococito
The engine is a 200tdi, the guy said it was reconed 10k miles ago, everything seems to be in good shape, no shaft play in the turbo, new steering pump, no leaks etc..
Post #510399 3rd Mar 2016 3:16pm
Browny90
I'd send it back, it's obviously not a genuine 200tdi if it doesn't have any leaks 😁 Whistle My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #510404 3rd Mar 2016 3:28pm
