Home > Technical > New defender not slowing down on over run. |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Sticky/frozen throttle cable.....do these modern new things even have cables,dunno!Does the throttle stick when your parked up (out of gear)?? Pov.spec,ftw. 2006, 110,TD5.
11th Feb 2016 2:15pm |
daedalus Member Since: 11 Feb 2016 Location: leeds Posts: 2 |
Hi, Thought of that and no it doesn't.
11th Feb 2016 2:18pm |
No cables for a long time. If it's new then take it back to the dealer. Steve.
11th Feb 2016 2:28pm |
Are the mats getting stuck in the pedal anywhere? Ray
11th Feb 2016 2:42pm |
JOE_130 Member Since: 26 Nov 2014 Location: Chelmsford Posts: 105 |
I would suspect mechanical issues with the pedal actuator. The pedal has a twin "rail" system that uses two different resistances travelling in opposite directions as the pedal moves as a fail safe to avoid issues like this or unexpected acceleration.
If its new just take it back to the dealer or preferably get it recovered by Land rover assist (you should have a few year's free cover with a new vehicle). The dealer should take the issue very seriously as its a safety critical concern. Its certainly not a "trait" of the 2.2 |
11th Feb 2016 3:19pm |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
Does it stay on mock cruise control for an extended period?
My 2.4 does continue for a bit after I let off the pedal but I'm pretty sure that's just reverse turbo lag, it certainly feels like it is. The turbo is a funny beasty, first time I gave my mum a lift she thought there was a police car behind us the noise it makes! |
11th Feb 2016 9:03pm |
CRC@LandRover Verified Account Member Since: 25 Mar 2013 Location: Coventry Posts: 383 |
Hi daedalus
Thank you for your post. I am sorry to learn of the concern that you have described and I would be happy to assist you in investigating this. In order for us to investigate or comment on the concern with your vehicle, it would need to be physically inspected by your local Land Rover retailer who will then be able to confirm their findings. Due to the nature of the concern, a road test with a retailer technician may be beneficial. If you would like to make me aware once your vehicle is booked in with your retailer and provide me with your vehicle and contact details via PM, I will be happy to see how we can assist. Regards Ryan |
17th Feb 2016 2:02pm |
Solihull Boy Member Since: 02 Oct 2012 Location: YORKSHIRE Posts: 68 |
Hi all,
My 2011 does as cupboard says, if you change from a wide throttle opening onto the brakes swiftly, the engine takes a good second or so to transfer from full power to overrun, which can be a bit disconcerting. The turbo makes a great noise though. The first time my wife travelled in the 110 she kept telling me to look out for the fire engine that was approaching. When I told her it was just the turbo she said, 'well in that case you'll have to get rid of that because I can't cope with that awful noise on a long journey'!! The issue I have with mine that the dealer has been unable to sort, is that it 'shunts' when cold and travelling downhill with just a whiff of throttle. It seems that the correct signal is not being sent or received some where in the fly by wire throttle, and it is as though the throttle is on and then off sharply which only get's worse and worse till I depress the clutch or apply throttle to stop the shunting. Regards Ged Retired from the day job and now self employed - what a life!! |
18th Feb 2016 12:08am |
LRNZ Member Since: 05 Nov 2015 Location: Auckland Posts: 27 |
Hmm my one does this too and I assumed it was normal. Might have to get it checked out.
20th Feb 2016 9:33am |
integrale Member Since: 29 Oct 2015 Location: Auckland Posts: 77 |
There are multiple posts about this. Search 'rev hang'. It appears to be very common. My new Heritage does it - badly. BAS offer a solution but warranty implications may concern some owners.
20th Feb 2016 9:57am |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
This has been a problem for some since the introduction of the 2.4. Could be me but some seem to do it worse than others. Defiantly software related, I have no idea why defenders do it but never experienced it in a transit..........
20th Feb 2016 10:38am |
