![]() | Home > Td5 > Starter motor removal |
Dixy Member Since: 30 Nov 2020 Location: Somerset Posts: 52 ![]() ![]() ![]() |
This is an excellent thread and deserves a sticky at the top of TD5 as I suspect a lot will be using it over the coming years.
This http://www.repairkitsuk.com/ is the website referred to for parts but you have to order through their Ebay shop, I have done and paid for fast delivery, I will update on the end result. |
have checked battery neg lead from battery down to chasse and on the transfer box to start with
Did you check the grease in the gearbox part? Mine was also going slow until I replaced the very hard grease for multipurpose. Roel
Checked the earth, ok. had checked the gearbox, ok. Took the whole thing out stripped down completely, blew out brushes, ran on bench ok with no load.
Time for a new one. |
