Home > Td5 > Starter motor removal |
Dixy Member Since: 30 Nov 2020 Location: Somerset Posts: 52 |
This is an excellent thread and deserves a sticky at the top of TD5 as I suspect a lot will be using it over the coming years.
This http://www.repairkitsuk.com/ is the website referred to for parts but you have to order through their Ebay shop, I have done and paid for fast delivery, I will update on the end result. |
11th Jan 2021 9:26am |
have checked battery neg lead from battery down to chasse and on the transfer box to start with
14th Jan 2021 1:31pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Did you check the grease in the gearbox part? Mine was also going slow until I replaced the very hard grease for multipurpose. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
14th Jan 2021 9:32pm |
Checked the earth, ok. had checked the gearbox, ok. Took the whole thing out stripped down completely, blew out brushes, ran on bench ok with no load.
Time for a new one. |
15th Jan 2021 5:13pm |
