Home > In Car Electronics > LED Stop/Tail lamp wiring question |
midlife Member Since: 15 Apr 2015 Location: Cork Posts: 122 |
Fog lamp single filament bulb hence two wires and different diffuse red lens. Stop/ tail light twin filament one for each function hence 3 wires
6th Feb 2016 5:45am |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
Given the picture and reading between the lines I assume this is a replacement for the fog lamp.
If this is the case you should use the brake and earth wires for the new lamp. The 3rd wire will be for the tail/running light, it's not bright enough for a fog lamp application. As a side note I fitted a reverse light to the fog lamp position and wired it to suit on mine. Cheers, Kyle. |
6th Feb 2016 7:01am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
You're replacing a single function lamp (fog) with a twin function lamp (stop + tail) so yes there are more wires
LED Single function lamps are available or you can wire just the brake element up on the lamp you have and leave one wire not connected. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
6th Feb 2016 8:34am |
GypsySamuraiAnt Member Since: 31 Mar 2015 Location: Brisbane Posts: 131 |
Thanks for the replies and I think I get it now.
So if you had to hazard a guess, which two wires would you say connect the tail lamp filament to the factory black & grey wires? |
6th Feb 2016 9:38am |
I think the colour code is moulded into the back of the lamp. And you want the stop element not tail element 1988 90 Td5 NAS soft top
2015 D90 XS SW |
6th Feb 2016 9:47am |
Spot on Martin! Black and red it is.
Thanks again, Ant. |
6th Feb 2016 9:53am |
The LED light units I have seen tend to have the wiring information embossed on the back of the unit.
LEDs are polarity sensitive, in your case you have two positive leads and one negative lead. There are 6 possible way of connecting those wires to a battery only 2 ways will energise the light. One way will be to tail light and one way the brake light. So a case of battery some wire and two croc clips? However would it be simpler to buy the correct unit with the correct connector already fitted? Brendan |
6th Feb 2016 9:54am |
