Home > In Car Electronics > LED Stop/Tail lamp wiring question
GypsySamuraiAnt
Australia 2015 Defender 110 Puma 2.2 SW Indus Silver
Hi folks,
I recently purchased a Wipac LED stop/tail lamp however it arrived with 3 bare wires compared to the factory lamp with 2 wires and a connecting plug as per the picture below;
I have found an ebay seller to sort the plug issue but wondering how to wire it up. Or should I have ordered the Wipac fog lamp with red lens? Does that come with only 2 wires?
Cheers,
Ant.
Post #501106 6th Feb 2016 4:05am
midlife
Ireland 2007 Defender 90 Puma 2.4 SW Rimini Red
Fog lamp single filament bulb hence two wires and different diffuse red lens. Stop/ tail light twin filament one for each function hence 3 wires
Post #501107 6th Feb 2016 5:45am
Alien
Australia
Given the picture and reading between the lines I assume this is a replacement for the fog lamp.
If this is the case you should use the brake and earth wires for the new lamp.
The 3rd wire will be for the tail/running light, it's not bright enough for a fog lamp application.
As a side note I fitted a reverse light to the fog lamp position and wired it to suit on mine. Cheers,
Kyle.
Post #501113 6th Feb 2016 7:01am
Martin
Site Admin
You're replacing a single function lamp (fog) with a twin function lamp (stop + tail) so yes there are more wires Wink
LED Single function lamps are available or you can wire just the brake element up on the lamp you have and leave one wire not connected.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #501141 6th Feb 2016 8:34am
GypsySamuraiAnt
Thanks for the replies and I think I get it now.
So if you had to hazard a guess, which two wires would you say connect the tail lamp filament to the factory black & grey wires?
Post #501179 6th Feb 2016 9:38am
Martin
Site Admin
I think the colour code is moulded into the back of the lamp. And you want the stop element not tail element Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #501186 6th Feb 2016 9:47am
GypsySamuraiAnt
Spot on Martin! Black and red it is.
Thanks again,
Ant.
Post #501191 6th Feb 2016 9:53am
leeds
The LED light units I have seen tend to have the wiring information embossed on the back of the unit.
LEDs are polarity sensitive, in your case you have two positive leads and one negative lead. There are 6 possible way of connecting those wires to a battery only 2 ways will energise the light. One way will be to tail light and one way the brake light. So a case of battery some wire and two croc clips?
However would it be simpler to buy the correct unit with the correct connector already fitted?
Brendan
Post #501192 6th Feb 2016 9:54am
