Home > Puma (Tdci) > Drive Flanges
Page 3 of 3 <123
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
Not counted. They are to suit a 2010 Puma, so I hope 24.
You cant buy the ones with splines at both ends from LR anymore. You get these beauties. They are cheaper than the others and include a flange.
Win!
Post #521221 5th Apr 2016 6:01pm
shaggydog
Interesting stuff.
Sounds like a decent upgrade then.
Sadly wont fit mine as I'm on drums on the rear so would need to chop the half shaft down a bit to get it to fit Rolling Eyes Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #521225 5th Apr 2016 6:20pm
Fatboy Slim
Wales
Better job all together
Post #521227 5th Apr 2016 6:21pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
so is there a reason why they from one-piece to two-piece design?
I mean surely the one-piece shaft will be much cheaper to make and fit,right?
Post #522082 8th Apr 2016 3:38am
LR90XS2011
I've been told that
1/ one piece are cheaper because there are less machining operations, generally people who off road prefer 2 piece as the flange / shaft interface is designed to break before anything else and make changing the broken flange / shaft easy, 1 piece ones have an undercut that is also designed to break first but makes it harder to get the shaft out of the diff/ axle when it breaks.
2/ The front has to be two piece because there is a CV joint between the shaft and the flange to allow the front wheels to turn the key with 2 piece is good lubrication on assembly,
3/ The spline failures are generally related to a dry joint so checking and lubrication front and rear 2 piece arrangement is a good idea DEFENDER 90 TDCI XS,
Post #522083 8th Apr 2016 6:25am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I have a worn shaft /flange on my 110
Shaft was £30, Flange was £15 (for an OEM part, nonetheless)
I think I'll stick to the 2 piece ones Whistle Thumbs Up
Post #522085 8th Apr 2016 7:03am
Fatboy Slim
Wales
I normally weld the rears Laughing
Post #522087 8th Apr 2016 7:19am
Cetane
Just a heads up... Splined joints, as with gears should be replaced as pairs. Otherwise you only solve half the problem.
You might find those new flanges don't last anywhere near as long as the originals did before getting to the same state because of the existing wear on the halfshaft.
Post #522131 8th Apr 2016 10:06am
Page 3 of 3 <123
