Home > Technical > Flywheel
MK
Flywheel
Sure the Puma has a single mass flywheel? Question Puma 110" SW
Post #43878 29th Oct 2010 10:40am
Tim_NZ
Australia
Yes, had a gander when the were doing the clutch (again).
Cheers,
Tim
Post #43881 29th Oct 2010 11:18am
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
I second that.No dual mass flywheel on Puma's Puma 110 SW
90 V8 SOFT TOP
Post #43905 29th Oct 2010 5:19pm
alantd
They looked at it but the standard duratorque dual mass flywheel wasn't strong enough. One that started out as a 2.4 TDCi 110 XS
Post #46359 25th Nov 2010 10:16pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
what does single mass mean - just one lump of steel? BM52
Post #46360 25th Nov 2010 10:54pm
TRR Motorsport
United Kingdom 2010 Defender 90 Puma 2.4 ST Galway Green
Yes, it does mate. "If it ain't sideways, you just ain't tryin'!
Post #46363 26th Nov 2010 7:23am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I thought dual mass flywheel was to fence the gearbox from the vibration induced by modern Diesel engines such as the Puma engine, does that mean that the gearbox is more likely to wear with a single-mass flywheel?
Note, if I remember correctly, on the TD5 some people where replacing the DMF with a single mass flywheel...
Post #46366 26th Nov 2010 7:51am
NoDo$h
Yes, DMFs are there to dampen/absorb vibration in the drive train but the upshot is that when they let go you really know about it. Common point of failure on modern diesels, along with EGRs and DPFs.
All a LOB IMHO.....
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #46373 26th Nov 2010 9:37am
