Home > Technical > Flywheel |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 |
Yes, had a gander when the were doing the clutch (again).
Cheers, Tim |
29th Oct 2010 11:18am |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 |
I second that.No dual mass flywheel on Puma's Puma 110 SW
90 V8 SOFT TOP |
29th Oct 2010 5:19pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
They looked at it but the standard duratorque dual mass flywheel wasn't strong enough. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
25th Nov 2010 10:16pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
what does single mass mean - just one lump of steel? BM52
25th Nov 2010 10:54pm |
TRR Motorsport Member Since: 07 Oct 2010 Location: Leicestershire Posts: 115 |
Yes, it does mate. "If it ain't sideways, you just ain't tryin'! |
26th Nov 2010 7:23am |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 547 |
I thought dual mass flywheel was to fence the gearbox from the vibration induced by modern Diesel engines such as the Puma engine, does that mean that the gearbox is more likely to wear with a single-mass flywheel? Note, if I remember correctly, on the TD5 some people where replacing the DMF with a single mass flywheel... |
26th Nov 2010 7:51am |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
Yes, DMFs are there to dampen/absorb vibration in the drive train but the upshot is that when they let go you really know about it. Common point of failure on modern diesels, along with EGRs and DPFs.
All a LOB IMHO..... 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
26th Nov 2010 9:37am |
