![]() | Home > My Defender > New to me Keswick 90 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10881 ![]() ![]() |
looking good, just fitting all of the galvanised hoops makes such a dramatic change, just awesome
![]() Cheers Clayton. |
Great work
![]() Surprised you got to keep the number plate?! |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 ![]() |
Another weekend & a bit more work on the landrover
Finally Fixed the hoops & the bulkhead removal bars - Because of the position of the hoop bars mounting, I had to drill through the Hoop mounting to fix the bulkhead removal bar to the hoop bar, so all in all a very strong and connected unit ![]() Click image to enlarge ![]() Click image to enlarge Fixed the front drivers side Door gutters. Given its a landrover tolerances a few washers were needed to get the alignment right. I suspect will need a bit more fettling once the hood is on ![]() Click image to enlarge 2020 P300 HSE |
Next it was fit the rear tailgate hinges - Excellent product from Purely Metal
![]() End result opened ![]() Click image to enlarge ![]() Click image to enlarge Then it was fit the spare wheel carrier - I went for the galvanised finish as I think it blends in better with the back of the vehicle - Thanks Brendan excellent choice - I used Brendan's knowledge to get the right product ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge That was all practical stuff, then I fitted a bit of bling ex FCX ![]() Click image to enlarge I finally took the hood out & laid it over the hoops so it can acclimatise before I try fitting it ! What I have noticed is that apart from the bulkhead removal bar, nothing has comes with any fitting instructions, it is very much trial & error to get everything fitting correctly ![]() ![]() Apologies for the state of my garage, we had to empty our caravan to go back to Swift to sort a leak ![]() ![]() |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 ![]() ![]() |
Can I ask how much the tailgate conversion hinges cost from Purely Metal please?
I think circa £120/£130
I've deliberately not kept any receipts so I do not know how much I've spent ![]() |
He hasn't ![]() Fantastic work ![]() Can we buy it back now ! |
Re the carrier its Safari equip from Brendan
I still have to:- Finish the passenger side drip guards Fit the hood Fit the alive tuning suspension Fit the new wheels Take the inside apart to fit an alarm & at the same time fit dynamat actually a cheaper alternative whose name eludes me Dynamat the rear tub Probably will fit heated screen & seat wiring for future use when the dash is in pieces ! That's about it for now 2020 P300 HSE |
Bit bored can do nothing tonight as we have a power cut & I cannot get in the garage
no portable generator
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3800 ![]() ![]() |
Looking great !!!
I also like the flooring in your garage where is that from, |
It was a late night ebay purchase a couple of years ago so sorry I cannot remember the name
They look like these though http://www.diyyourgarage.co.uk/collections/flooring-solutions 2020 P300 HSE |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
Some Heritage mud flaps will finish the back end off
![]() Are you going for a retro badge too? |
I've cocked up on a wheel purchase as they just look wrong
![]() Will have to stay on the vehicle for a while & will see if they grow on me Soft top fitted - at least I feel I'm getting somewhere now ![]() ![]() Click image to enlarge As you can see wheels are just not right ![]() Click image to enlarge Yes have some retro badges to fit but just some ordinary LR mudflaps 2020 P300 HSE |
