Home > My Defender > New to me Keswick 90 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10719 |
looking good, just fitting all of the galvanised hoops makes such a dramatic change, just awesome
Cheers Clayton. |
3rd Feb 2016 10:58pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7895 |
Great work
Surprised you got to keep the number plate?! |
3rd Feb 2016 11:16pm |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
Another weekend & a bit more work on the landrover
Finally Fixed the hoops & the bulkhead removal bars - Because of the position of the hoop bars mounting, I had to drill through the Hoop mounting to fix the bulkhead removal bar to the hoop bar, so all in all a very strong and connected unit Click image to enlarge Click image to enlarge Fixed the front drivers side Door gutters. Given its a landrover tolerances a few washers were needed to get the alignment right. I suspect will need a bit more fettling once the hood is on Click image to enlarge 2020 P300 HSE |
8th Feb 2016 8:22am |
Next it was fit the rear tailgate hinges - Excellent product from Purely Metal
End result opened Click image to enlarge Click image to enlarge Then it was fit the spare wheel carrier - I went for the galvanised finish as I think it blends in better with the back of the vehicle - Thanks Brendan excellent choice - I used Brendan's knowledge to get the right product Click image to enlarge Click image to enlarge Click image to enlarge That was all practical stuff, then I fitted a bit of bling ex FCX Click image to enlarge I finally took the hood out & laid it over the hoops so it can acclimatise before I try fitting it ! What I have noticed is that apart from the bulkhead removal bar, nothing has comes with any fitting instructions, it is very much trial & error to get everything fitting correctly saying that it has mostly been straight forward although sometimes it would have been nice to have instructions for a sense check on what I was doing Apologies for the state of my garage, we had to empty our caravan to go back to Swift to sort a leak , so have the contents of the caravan including all the cushions for 6 weeks 2020 P300 HSE |
8th Feb 2016 8:32am |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 |
Can I ask how much the tailgate conversion hinges cost from Purely Metal please?
8th Feb 2016 5:39pm |
I think circa £120/£130
I've deliberately not kept any receipts so I do not know how much I've spent 2020 P300 HSE |
8th Feb 2016 6:08pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 |
He hasn't Fantastic work Can we buy it back now ! |
8th Feb 2016 7:00pm |
Re the carrier its Safari equip from Brendan
I still have to:- Finish the passenger side drip guards Fit the hood Fit the alive tuning suspension Fit the new wheels Take the inside apart to fit an alarm & at the same time fit dynamat actually a cheaper alternative whose name eludes me Dynamat the rear tub Probably will fit heated screen & seat wiring for future use when the dash is in pieces ! That's about it for now 2020 P300 HSE |
8th Feb 2016 8:34pm |
Bit bored can do nothing tonight as we have a power cut & I cannot get in the garage 2020 P300 HSE
8th Feb 2016 8:36pm |
no portable generator
8th Feb 2016 8:59pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3739 |
Looking great !!!
I also like the flooring in your garage where is that from, |
8th Feb 2016 9:20pm |
It was a late night ebay purchase a couple of years ago so sorry I cannot remember the name
They look like these though http://www.diyyourgarage.co.uk/collections/flooring-solutions 2020 P300 HSE |
9th Feb 2016 8:21am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10378 |
Some Heritage mud flaps will finish the back end off
Are you going for a retro badge too? |
12th Feb 2016 8:33am |
I've cocked up on a wheel purchase as they just look wrong
Will have to stay on the vehicle for a while & will see if they grow on me Soft top fitted - at least I feel I'm getting somewhere now Click image to enlarge As you can see wheels are just not right Click image to enlarge Yes have some retro badges to fit but just some ordinary LR mudflaps 2020 P300 HSE |
12th Feb 2016 9:12am |
