![]() | Home > Puma (Tdci) > Temperature gauge |
Coolcamper55 Member Since: 22 Apr 2010 Location: Inverclyde Posts: 45 ![]() ![]() ![]() |
My gauge has suddenly stopped working.
It moves very slightly when ignition is switched on but does not rise with the engine temperature rising. I knew the engine was warm as the heater produced hot air and strangely the Torque diagnostics registered 59 deg I have checked the wiring diagrams and cannot find any reference to the gauge. Is there a fuse somewhere. I have also checked the ws manual and it sheds no light. Grateful for any help Tommy 110 XS TDCi |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
have you checked the sensor on the block no lose wires
if you take look on the link and down the page manuals and wiring manual for 2.4 puma
http://forums.lr4x4.com/index.php?showtopic=55983&page=4 if you can get use ecu diagnostic you work it out |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
The gauge is controlled by CAN bus messages, are you getting the glow plug light and battery charge warning light coming on when you turn the key on?
I have both the documents you speak of and have infact said so in my original post. Thanks Tommy 110 XS TDCi |
I do indeed get all the indicator lights you mentioned and the fuel gauge also works. Thanks for your support Tommy 110 XS TDCi |
New CHT arrived today. Will try and fit it tomorrow.
Thanks again for input Tommy 110 XS TDCi |
New CHT fitted. All back to normal.
Thanks for assistance Tommy 110 XS TDCi |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2929 ![]() |
What's the CHT?? Just noticed mine this morning is sitting just above the blue, and the blower temp is def down... Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
Cylinder head temperature. Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
