Home > Puma (Tdci) > Temperature gauge |
Coolcamper55 Member Since: 22 Apr 2010 Location: Inverclyde Posts: 45 |
My gauge has suddenly stopped working.
It moves very slightly when ignition is switched on but does not rise with the engine temperature rising. I knew the engine was warm as the heater produced hot air and strangely the Torque diagnostics registered 59 deg I have checked the wiring diagrams and cannot find any reference to the gauge. Is there a fuse somewhere. I have also checked the ws manual and it sheds no light. Grateful for any help Tommy 110 XS TDCi |
25th Jan 2016 2:22pm |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
have you checked the sensor on the block no lose wires
25th Jan 2016 2:29pm |
if you take look on the link and down the page manuals and wiring manual for 2.4 puma
http://forums.lr4x4.com/index.php?showtopic=55983&page=4 if you can get use ecu diagnostic you work it out |
25th Jan 2016 3:11pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6604 |
The gauge is controlled by CAN bus messages, are you getting the glow plug light and battery charge warning light coming on when you turn the key on? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
25th Jan 2016 4:26pm |
I have both the documents you speak of and have infact said so in my original post. Thanks Tommy 110 XS TDCi |
25th Jan 2016 7:47pm |
I do indeed get all the indicator lights you mentioned and the fuel gauge also works. Thanks for your support Tommy 110 XS TDCi |
25th Jan 2016 7:49pm |
New CHT arrived today. Will try and fit it tomorrow.
Thanks again for input Tommy 110 XS TDCi |
26th Jan 2016 3:30pm |
New CHT fitted. All back to normal.
Thanks for assistance Tommy 110 XS TDCi |
31st Jan 2016 5:12pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2892 |
What's the CHT?? Just noticed mine this morning is sitting just above the blue, and the blower temp is def down... Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
29th Feb 2016 8:53am |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 |
Cylinder head temperature. Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
3rd Mar 2016 7:52am |
